Old 06-11-2010, 08:17 AM
Bonestock's Avatar
Bonestock Bonestock is offline
Nürburgring Warrior!
Go me.. A/C died yesterday!
Do yo know how hot a black on black on black car in Florida gets in the summer? OMG!!!!!! I was heading out to pick up a tow hitch from my wife's SUV and my A/C started getting warmer and warmer. I usually am very comfy with it set on auto 74. I start dropping the temp to 65 and it finally starts blowing warm. First chance I get to look under the hood, there is a yellow leak dye and PAG oil all around the back of the pass side headlight, pool under the charcoal canister and even in the undertray. Good times. I cant wait to have a look at how hard to find and how expensive replacement parts are gonna be. Go me!
Old 06-11-2010, 08:23 AM
Re: Go me.. A/C died yesterday!
New condensor is only ~$275 ish. That's about the worst case scenario. I'd check the lines leading from the condensor to the dryer canister, and the o-rings on the dryer canister connections.
Old 06-11-2010, 08:31 AM
Bonestock's Avatar
Yeah checking the o rings on both ends is the first place I am gonna start. If I am lucky, it will only be an o-ring and a recharge... if not........... a CTSV is in my very near future.
Old 06-11-2010, 08:39 AM
The A/C lines are fairly inexpensive and easy to replace. I don't see why that would discourage you, unless your car has an encyclopedia's worth of other issues.
Old 06-11-2010, 08:57 AM
Bonestock's Avatar
Oh no not at all... its a mint 80k mile 92 LS-L. I am just being "cheeky". And I do want a CTSV...
Old 06-11-2010, 09:51 AM
Bonestock's Avatar
Had a quick look... it appears that the leak occurred on the high pressure switch located between the receiver dryer and condenser. I say that because the majority of leak dye is concentrated below the r/d (there is a puddle) and all over the high pressure switch. Even the charcoal canister (side facing the front of the car) is coated. Now I will have to try and pressurize to verify. Lets hope its something simple.
Old 06-11-2010, 09:54 AM
The pressure switch was leaking on one of Tom's old Pearlies. That makes sense.
Old 06-11-2010, 06:04 PM
what about the compressor itself? that's be ruled out as the culprit? Wouldn't that be the most expensive part of the system to replace?
Old 06-11-2010, 10:27 PM
92_LSL's Avatar
92_LSL 92_LSL is offline
i know how you feel man. my svx is black on black and i also live in florida. my ac compressor went out a few months back.
I has teh FWD LS-L
Old 06-12-2010, 07:11 AM
dcarrb dcarrb is offline
You can get a remanufactured compressor for about $350.
dcb
Old 06-12-2010, 09:02 AM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
dcb
Holy hell. If my uncle could still pull money from behind my ear I'd get a new compressor but that's steep..
Any aftermarket options or maybe something we can pull off another car?
Old 06-12-2010, 09:33 AM
Actually, I remembered wrong. This one has been on my silver for over a year now (only I think I paid more):
http://www.partstrain.com/store/deta...RMS191113.html
R-134a. Good and frosty.
As I recall, OEM is about $350 times two.
dcb
Old 06-12-2010, 11:16 AM
Bonestock's Avatar
I went by and chatted with the previous owner. The hard line and pressure switch are 2 yrs old. He'd know because the exact same thing happened on this car while he owned it.
I ordered a new switch (and line) from Subaru $73 iirc.
The question is, why did both switches fail? Typically pressure will build if there isnt sufficient cooling of the condenser. ie external blockage, aux fan inop etc. So I guess I am going to have to give the entire A/C system a thorough inspection.
Old 06-14-2010, 08:32 PM
Bonestock's Avatar
Just FYI, the hard line & high pressure switch... I ordered the last one in the country. No more... nadda ZIP!
Old 06-15-2010, 12:22 AM
Not cool man. Not cool.
