can drilled rotors be turned in a lathe?
hi folks!
i just picked up a nice rolling shell with a TON of good stuff on it... i think its the in the best shape rust-wise of the three i now have, so IT will be the basis of the rally beastie! ![]() it has nearly new drilled brake rotors and pads, with only a small amount of rust on rotor surfaces due to being parked for a few months.. can these be cleaned up in a brake lathe? or does the cross drilling "fetch" on the lathe teeth and cause an issue with the brake guy? ![]() thanks! rob ![]()
i'm too svxy for my car rob ![]() 92 ebony 4.44's rock !! ![]() |
Re: can drilled rotors be turned in a lathe?
I have had my drilled/ dimpled rotors cut down slightly. The shop had no problem doing this.
Turned without catching on the edges of the dimples. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
Hope this helps - 'skimming' the discs is possible whatever the ventilation. What I have found, though, is that you need to bed them in and form some kind of 'skin' on the surface before you work them hard. If not, they warp. Discs aren't very dear to buy new these days btw.
I wouldnt even bother lathing them for a little bit of rust. If you are installing new pads, a thin coat of rust is actually beneficial. Remember lathing reduces the amount of metal in the rotor leading to faster brake fade and greater chance of warpage.
yeah...i've been debating the worthiness of even bothering...the rust REALLY is almost not there....
to be honest, ANYthing is better than what i'm running now! lol rust and all.... ![]() im able to get genuine subey parts at below dealer cost (thank gawd for friends in high places!!) even so, 4 discs and f/r pads came to 800$$ !!!! gulp!! in hindsight, i shoulda bought off of ebay.... oh well... thanks for the input everyone! that will be next weekends project...sexy new brakes!! ![]()
BTW Steel Subaru marks their stuff up over Subaru Canada retail by 15% or so. O'Regan's in Bridgewater is fair price and most anyone can get the "shop" discount. Quote:
Peter ART Cryogenic/Slotted Rotors, Stainless Steel Brake Lines, PWR Radiator, Tranny cooler, Stebro, Earthworm's Poly Differential/front & rear swaybar bushings, Koni Inserts and Mychailo SVX Sport Springs all 4 corners, Indigo Blue paint. Liquid Silver Wheels. Last edited by SVX_MY_BABY; 05-16-2010 at 01:06 PM. |
sadly its too late now...they've been on the car for two years...
![]() my source is awsum....genuine Subey rad taxes included brand new was sub 400$ front fenders are (i think) 125$ same with rear quarters.... ![]()
To answer the original question, yes they can be turned but you need a "rounded" bit. Very few places use these as they are more expensive than standard tips.
ahhhhhh
they must be awful expensive....ive been in/around shops for ummm gee 25 years now and all ive ever seen were the traditional triangular bits... i didnt even know there were other types!! (although it makes sense in retrospect......) ![]()
How does a rounded bit "cut" instead of just score?
Just the cutting edge is curved, so it removes metal progressively across the holes.
![]() Harvey
I had 'em.. . Dint like 'em! Never noticed any better braking, but some shops won't turn 'em.. . some will. Best to countersink if they're holes. Ironically, the small shop by my work wouldn't touch 'em for a $12 a rotor turn, but the Pep Boys would turn 'em for $4! Ha!
I get standard rotors from Autozone or Pep Boys.. . no problems. The cross-drilled rotors warped sooner for me too! Jim ![]()
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) ![]() ![]() |
yep!!
my poor departed mom always said the day ya stop learnin is the day ya die! lol i guess she was right! god bless her heart! ![]()
