Re: SVX trim code registration: please submit your details
It is an option, the Japanese sheet is lacking
Special Thanks to Our Friends and Sponsors: * http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/ http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston "QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works, '92 Subaru SVX LS-L Claret ORIGINAL OWNER '92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~ '92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143 '92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117 |
Paul's post is consistant on DJW SVX, as a tri-tone (DV) CXD, this car also coded C.
Darren's car coded DWC. My black V-L, DXC, has holes in the rear shelf for the aircon unit, and a fan switch. My Pearl V-L, DWC, has no holes, and no switch, I can see the evidence of the tri-tone Option Code with Earl and DJW SVX, but the C code is a bit more confusing. [you were right Earl, sorry I didn't read the thread carefully enough, I was engrossed in the Japanese sheet Phil attached ]
The reason the full auto aircon is not listed in Phil's Japanese option list Ron is because it was not an option. All Japanese SVXes even down to the very cheapskate 94-95 ones came with full auto aircon as standard. Therefore it does not need an option code. Joe
I'm aware that the auto aircon is standard in every SVX, that's why the C is confusing, if that is what it relates to, and if so, the reason the C is deleted from the Japanese sheet.
You will note that Paul has listed Auto Aircon even though I maintain it is not really an "option". You could not buy an SVX without it, it was standard in Japan. Note also that in Phil's list the basic CXW car has the option code AX. This car is shown with no available options and it's presumed it has aircon as standard. The letter C on the VIN plate indicates only that it is a 3-tone car, so this letter C will not be on all cars, only the silver ones. Joe
The letter C appears on both of my VLs, on Darren's VL, on Phil's VLs, DXC, DWC, these are not silver or tri-tone cars? I do believe the options on the Japanese web-link correctly depict the only Option codes for VE and VL, can we assume the same Options and same code exist for all CXW JDM models, including S40, S40II, S3 and S4?
It does have the air purifier, so does my black VL, but not the claret. I think these were dealer fitted because the wiring is badly spliced in, not part of the loom.
Is the air purifier in the JDM Accessory catalog? The JDM rear wing, lower side graphics, and other accessories must be dealer installed, just as the upper side 'subaru svx' graphics and rear wings on US models were installed a port.
