big overhaull
hello people!
today, it's my first day of vacation ![]() i have all parts to overhaull my dear svx ![]() so about the work, we doing : - timming belt replacement - A/C belt replacement - ACC belt replacement - sparks replacement - air / fuel / oil filter replacement - cooling fluid / engine oil / power steering oil replacement - somes stupid parts so let's do this! |
Re: big overhaull
If you're lucky, you will only use one day of your vacation to do this...
and enjoy the rest of your vacation driving your svx and enjoying the fruits of your labor. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
Re: big overhaull
1st day :
first, remove engine undercover and both 2 upper covers. remove battery from the car and the plastic thing bellow the battery. ![]() after do that, remove the down hose of the radiator. cooling fluid comes out so put something to keep it and discard it. remove the upper hose and the hose coming from to the cooling fluid canister. cooling fluid comes out so put something to keep it and discard it too. now, remove the 2 littles hoses at the lower of the radiator ( it's probably gearbox oil fluid ) fluid comes out so put something to keep it and discard it. you can disconect fans, remove the upper brackets and pull out the radiator assy whit fans. ![]() you can remove the front grill to have more access ( 2 clips at upper ) and you going like this : ![]() ![]() now, you can loose the nuts of the power steering belt thighter. ( 1 nut and the screw ) ![]() that can loose the belt and you can remove it. mine was in very bad condition! ![]() now loose the 2 nuts of the A/C blet tighter. ( 2 nuts ) that can loose the belt and you can remove it. not really nice condition too. now, you can remove the 2 tighter brakets. 3 bolt of the A/C one and 1 nut for the steering one. disconnect the hose of the power steering pump. the hose pass just in front of the right side of the engine. doing that give you more space to check the timming belt of the right side of the engine. look out from the leaking fluid! ![]() thats all for today! tomorow i'll go remove alternator and power steering pump and remove timming belt covers. see you tomorow! ![]() Last edited by Naru; 03-29-2010 at 10:10 AM. |
Re: big overhaull
Wow, needs a good cleaning. Make sure you get lots of nice "after" shots!
Re: big overhaull
yeah.
this car is old and not realy good maintenance. i'll gonna clean all before reinstall all of the parts. and you know, the black dust on the engine is from? its from steering belt! scary!!! lol |
Re: big overhaull
I had some issue when I first got my svx where it kept eating my power steering and a/c belts. It was so bad that I needed a new belt every week. Eventually, I got some money and OT fixed the problem for me. The belts beat the crap out of my hood though.
1992 Pearl White LS-L "Ruslana" #4946 - 180k on body, 95k on engine. Mods: ECU bead crush, 15 min mod, 20 min mod, drilled/slotted rotors & Axxis ceramic brakes, SS lines, 17" Evoke F1 wheels, XS-HF137 Sony Xplod speakers, 6000k HID's (lows & fogs), resistor mod, 1½" Sleek Spoiler mod, custom exhaust by svxfiles, '02 WRX aluminum racing radiator by svxfiles, Summit Racing 400# x 300# springs w/ Koni's by svxfiles, ClassGlass fiberglass hood /w scoop, Nevin's rear sway bar, '97 grille, phenolic spacers, custom LED interior lighting, custom paint. †"War doesn't determine who is right, only who is left"† Work to be done: Tinted windows, clear/LED tail lights, tailbar mod, "Power Mode" mod, Supertone horns, clear corners & headlight lenses, 2 pc splitters or custom bumper, Alcyone side skirts, TruSpeed Stage III SVX Intake, Hydra, 4.44 tranny swap, JDM auto folding side mirrors, engine rebuild, super charger, STi seats, bone leather interior /w SVX emblem, dash overhaul, SVX decals, paint (stock color). Total cost?: 22k ![]() |
Re: big overhaull
OT ?
Re: big overhaull
"Old Tom" as he is referred to here. His handle on the forum is svxfiles
Re: big overhaull
okey i understand. tks!
Re: big overhaull
2nd day
remove power steering and A/C belts tighters. 3 bolts for the A/C belt and 2 for the steering one. ![]() after removed the hoses and the plugs from the steering pump, remove the 3 bolts of it to remove the pump assy. ( check the" how to " to see whitch bolts. not nessessary to remove the tank from the pump by the way. ![]() ![]() remove bolts of the alternator. dont forget the plug and the wire. remove alternator. remove the bracket of the canister in the right of the engine. dont forget to disconnect hoses. 2 bolts here ![]() remove the horn bracket too. 2 bolts and one plug ![]() wow! it's seems there is a forest bellow my intake manifold! lol ![]() remove the crank pulley. use any method u think good. it's not the post to talk about it. i have use an good 22 wrench and hit it whit a rubber hammer. that come easily for me! ![]() remove the right shroud, the left shroud and the center shroud of the timming belt. that's look like this : ![]() ![]() |
Re: big overhaull
Re: big overhaull
and about the spring tighter?
just remove it : 2 bolts and use something to compress it and lock it by using the holes. okey, i know, my method is not realy "hi-tech" but works realy nice ^^ ![]() ![]() have you change all the cranks and pulley? ![]() so instal the spring tighter and the tighter pulley. ![]() |
Re: big overhaull
check if the old timming belt is the same as the new one.
you can check if it's the same amount of teeths bettwen marks of the old and new one. it's ok for me, so put it in position! ![]() ![]() ![]() ![]() |
Re: big overhaull
all points and marks alligned?
so remove the thing you use to let the spring tighter come back in position. ![]() now, u can install freely the crankshaft pulley, and use it to make the engine have somes turns. for my case, i have done 3 revolutions. the marks of the belt are unalligned whit the mark of the pulley? dont panic. just allign the crankshaft and check the allignement of the camshafts. all is ok! ![]() now u can install all things like the removal but in the other way. after that, you can add cooling fluid and power steering fluid. now you can start the engine and check if all is ok. donc forget to add cooling fluid, power steering fluid and tranny fluid if nessessary. ![]() |
Re: big overhaull
Excellent thread, Naru. Very detailed and precise. Easy to understand even with the "slight" language barrier
