Old 03-18-2010, 06:56 PM
storm66's Avatar
storm66 storm66 is offline
Imagine...
90-98 Legacy Manual Transmission Service Manual
Took 93 Legacy transmission apart as it was making a roaring noise. Found some bad bearings. Anyone have a service manual that would have bearing part numbers in it that you could email me? What is the best place to get parts for the transmission?
94 Laguna Blue LSI 126k (stock)
92 Silver LSL 106K (highly modified)
Old 03-18-2010, 07:37 PM
trophy956 trophy956 is offline
Re: 90-98 Legacy Manual Transmission Service Manual
the rear bearing on the main shaft ? and what other bearings ,give me the taz number if you have it ,it would be by where the starter mounts
Old 03-18-2010, 07:48 PM
storm66's Avatar
Imagine...
Two numbers there:
3V-FY752VA2AA
688840
Front main input shaft bearing and seal, rear main input shaft bearing (big one) and extension housing bearing (has shaft in it that uses ring clip and has large ring clip holding bearing in.
Thank you for your help in advance.
