Old 02-26-2010, 06:57 PM
K_Dub's Avatar
K_Dub K_Dub is offline
Headin' for the hills
FWD fuse to disconnect driveshaft
Does putting in the FWD fuse stop the driveshaft from spinning? Or does it just spin with the tires without any power going through it? I've got the fuse in but still have the metal scraping sound up front that my mechanic told me is my driveshaft.
'92 LS-L "Bandit" #362 formerly dark teal, repainted by prev owner
Mods: ECUTune 2v7f, Earthworm bushings, Pioneer DVD/Bluetooth phone, Infinity Reference all around, tint, 17" wheels, custom seat belt computer, velcro visor
Buying parts is like car payments. Someday she'll be all mine.
Old 02-26-2010, 07:37 PM
Trevor's Avatar
Trevor Trevor is offline
Re: FWD fuse to disconnect driveshaft
The shaft will still rotate driven via the wheels, as you have suspected. The switch fuse will only prevent drive from the engine and transmission, as a result of preventing the centre clutch from engaging.
Trevor, New Zealand.
Old 02-26-2010, 07:40 PM
If you have an AWD car, and the driveshaft is connected and not broken, it will spin as a result of the rear wheels turning, regardless of the fuse.
A very common cause of the driveshaft scraping is a bent heat shield.
Why don't you remove the aluminum heat shield above the exhaust, and below the driveshaft?
Old 02-26-2010, 09:14 PM
K_Dub's Avatar
Yeah, I've figured a lot out since I posted this roadside. I hadn't really thought things through, nor tested, or looked underneath, so... Yeah.
Thanks for your input.
Seems like they just slapped my car back together when they saw that the driveshaft they ordered was too short. So the heat shield is scraping, which it wasn't when I dropped it off, and the same vibration as before kicks in at 20-30mph. I was just freaked when I got in and it was scraping so bad, so I pulled over, got out the iPhone, and hit up the best SVX mechanics in the world.
I love this forum.
Old 02-26-2010, 10:06 PM
Your post speaks of vibrations...
And of a wrong replacement driveshaft.
Can you take your original driveshaft to a driveshaft specialist and have him de-stake the U-joints and replace them?
U-joints are only $25-$30 or so each, the tough part is finding someone who can reassemble it without causing a vibration.
Old 02-26-2010, 10:08 PM
If you want, I can see about rebuilding one here..
Shipping should not be that much if I split it into two pieces that you can bolt back together.
Old 02-26-2010, 11:18 PM
K_Dub's Avatar
Sorry, I've got some of these details in a Parts Wanted thread, and other breadcrumbs scattered over the forum for the past few months. I'm making a mess of the internets, I know. Maybe I should start from the beginning while I've got your attention.
I've had a rough vibration between 20 and 30 mph for the past few months. While I was installing new swaybar bushings and rear-diff bushings I saw that my CV boot was torn on my passenger front axle, so I figured I'd finally found my problem. I took it to an independent Subaru shop (after being told by 3 shops that they didn't work on SVX's), and they replaced the whole axle and both boots about a month ago.
While it was A problem, the axle wasn't the cause of my vibrations. So I saved my pesos and brought my car back to them on Wednesday. They said that my driveshaft was causing the vibrations (which I'd come to suspect) and also that my passenger rear bearing was shot (also no surprise). They found a "used '94 SVX driveshaft" for $350 local, and I told them to hold off. Enter my "parts wanted" thread. I found another one at a nearby yard for $200, but then they called back and said it wasn't from an SVX after all. So I pulled the trigger on the $350 one only to find out today at 4pm that it was too short. They claimed that the two-piece redesign wouldn't fit my car and I need one from a '92 or '93. I'm not buying it. Turns out I was offered two overpriced Legacy driveshafts in just 24 hours.
So I left the garage as they're closing up for the weekend and my car is making a horrible scraping sound from the front end. I freaked out a bit. I called the shop, as they'd closed the gate behind me, and they said that it was just a little worse off than before and to "take it easy on the throttle."
I've been searching here since I crippled it home, and yeah it sounds like the heat shield to me. I've also been learning about durability issues with the early one piece driveshafts, so now I'm thinking that upgrading to a later two piece might be the best idea. Tomorrow I'm going to get under there and see if I can get that heat shield back where it was before so I don't have to listen to it, then I'll be tracking down parts to get shipped. I might very well take you up on your offer Tom.
Thanks for listening. That was therapeutic.
Old 02-27-2010, 07:35 AM
OK, thanks for explaining.
1)All SVXi had the same length driveshaft.
2)The term "one piece" refers to a two piece driveshaft, that does not unbolt in the middle BUT it still has two sections of driveshaft with a flex joint connecting the two pieces.
3)In all of the worn out SVX driveshafts that I have seen, all of them had either the front U-joint, or the rear U-joint bad and never yet the middle one.
Is your bad driveshaft one that can be unbolted in the middle?
Is the front, rear, or both U-joints notchy?
Old 02-27-2010, 02:31 PM
K_Dub's Avatar
1) Yeah, I figured as much after searching here. It sucks; the only mechanic I can find to work on my car doesn't even know what one looks like underneath.
2) I might still be confused on this, so let's clarify. Mine is the kind that bolts in the middle. That's the earlier kind (which I've been wrongly calling the one piece) right?
3) I suppose that could be read as case for the later ones with the center joint, correct? I haven't figured out if it's the front or back U-joint that's problematic, although I wouldn't be surprised if it's both considering the mileage. My understanding is that if I want to replace it all I should have my choice of any year as long as I get the entire assembly from trans to diff.
Hopefully I can get it down to my friend's house in the valley tonight to get underneath it as see stuff for myself. It's pouring outside and my driveway is steep and muddy.
Old 02-28-2010, 12:54 PM
K_Dub's Avatar
What're the odds these guys are telling the truth?
http://www.wholesaleimportparts.com/...rive_Shaft.php
They claim to have 6 in stock, and the price is comparable to the used Legacy one I almost got Friday.
I'm also considering:
http://driveshaftmasters.com/
or
http://www.wencodriveshafts.com/
or for a price
http://www.acpt.com/driveshaft/index.html
Finding a decent mechanic can be a real problem, but am I making it more difficult than it needs to be when it comes to parts? I mean, this is LA, there's custom performance shops on every corner. I looked at all the discussions on here about aluminum or carbon fiber parts, but didn't see anyone who actually committed to it. Is anybody out there running a non-OEM driveshaft? How's that working out for you? Any way I slice it I'll be spending over $500 on this job, so why not open up my options?
Old 02-28-2010, 01:17 PM
trophy956 trophy956 is offline
hi there are 2 different drive shafts used in SVX ,one with center u joints this one is used in L models ,the type with a DOJ type center joint used in LS and LS L models ,the giggest problem with putting u joints in subaru shafts is they are staked in place at the factory ,i talked with a few shop here and they wont touch one because pressing them apart stresses the yokes and they crack a few miles after use
you can buy new factory one for 500.00
good luck
Old 03-01-2010, 05:53 PM
K_Dub's Avatar
good luck
OEM driveshaft assy (PN 27031AP060) is $603.61 from my friendly local stealership. Ouch. My mechanic is saying his guy can rebuild mine, but while I'm sure OT could do it right I just don't trust some "guy" to not screw it up. I talked to a couple of the links I posted previously and wasn't too impressed. The shop that claimed to have 6 in stock put me on hold for 15min and then hung up. The others were not willing to back up their work saying that if it's out of balance then tough luck.
I've even looked at shipping one from Wiley Ford, WV and that'd add another couple hundred to the cost of the part.
I'll update my parts wanted thread, begging for help. I really hope I don't end up getting a $603 driveshaft.
Old 03-05-2010, 04:27 PM
K_Dub's Avatar
All fixed up.
Thanks to 1986nate for the part, and everyone else (especially Tom) for your advise. I looked at the old part and compared it's motion to my replacement. The front U-joint could rotate a little bit on it's own and felt flimsy, the mechanic said he'd never seen one that bad. Lucky me it didn't come off while driving.
I wonder what could have resulted in this failure. I'm sure that 200k miles had a lot to do with it, but when I bought my car the rear diff bushings as well as subframe mounts had a lot of play in them. I've since installed Earthworm bushings and done the 15min mod, so it's pretty tight now, but I wonder if the rear end wiggling could have caused this. It was apparently already on it's way out when I purchased the car because it's always vibrated a little during hard acceleration, but not any more. Everything feels tight and smooth at all speeds up to 70mph, so I'm a happy camper.
BTW, I should clear the name of Doug's Legacy Automotive while I'm at it. They were sold the wrong part by a wrecker, and didn't charge me a thing for their attempt to fix it last week. Talking to the guy this morning, he had a lot of the typical misconceptions about SVX's but he loves working on Subarus and with me around he'll get a few more tries at the SVX. Nice guy, fair rate, and totally agrees with me that Subaru hasn't built anything worth owning in the past two years. If you're in LA and can't find a mechanic, give him a shout.
Old 03-05-2010, 04:44 PM
Awesome to hear Kit! Glad I was able to help you out and get it out there right away Now you can enjoy another 200k out of your SVX
Old 03-05-2010, 08:50 PM
All fixed up.
Thanks!
