Old 12-30-2009, 06:41 PM
Exclamation OEM EG33 engine reseal kit
I know there have been discussions/arguments on here that I have seen a few times about what is and is not included in the OEM engine reseal kit for the SVX, mainly pertaining to the 20 valve cover "washer" gaskets. Many have said/thought that these are not included when in fact they are. My point of this thread is just simply to clarify exactly what is and what is not in this kit. I can type in all part numbers included and scan the printout that I have when I get a chance probably after the weekend. If anyone is curious about anything before I get this posted, they can ask on here and I will get back as soon as possible.
-Nate
Also, if the mods think that this is pointless, then they can go ahead and delete this, doesn't matter to me
Old 12-30-2009, 10:36 PM
Re: OEM EG33 engine reseal kit
Mine contained all 20 valve cover bolt gaskets. It did not, however, come with the half moon seals that go at the rear of the heads (P/N 11051AA070, 4 req'd). I also do not believe it included the water pump gasket or thermostat gasket (P/N 21236AA010 and 21114AA051).
Old 12-30-2009, 10:39 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Whered you get it Nate? I need to do mine bad!!
Old 12-31-2009, 12:23 AM
It does come with a Water pump gasket (21114AA050 GSKT-WATER PUMP) also has "SEALING-WATER PMP" #21116AA020. It does not appear to have the half moon seals as you say or the thermostat gasket.
Is there anything else that I maybe should get other than the 4 half moon seals (are these possibly meant to be reused? just curious, that's all) ? I am getting all of these parts for a forum member in Australia as the parts there cost so much.
And I got them from 1stsubaruparts.com. $235.72 and if that's all you bought, it's 10% shipping so $23.58 shipping on just this.
Also, ordered a bunch of other parts(some that needed ordering in) and total time from placing it to it arriving at my doorstep was 16 days. From when they sent the email saying it was shipped, just 2 days from WA to WI. Shipped Mon, got it Wed evening.
Old 12-31-2009, 12:35 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Does anyone know the link to the valve cover gasket how-to ??
Old 01-04-2010, 07:36 AM
STeeL25T STeeL25T is offline
Soon to own a fuctional SVX
Send a message via AIM to STeeL25T
I got my kit but I haven't had time to look through it much, does it come with valve seals or other head related things like that?
Old 01-04-2010, 12:06 PM
Yes it does, Joel (aust92pearl) who I ordered the kit had also wondered and both YT and someone else confirmed they do come with it
and as noted previously in this thread, it does not come with the half moon seals for the heads...
Old 01-04-2010, 12:13 PM
svxcess svxcess is online now
YT ordered a complete seal kit for me when he rebuilt my engine.
It came with the valve seals and head gaskets. He gave me credit for the head gaskets since I was using the Cometic ones.
Old 02-02-2010, 11:38 AM
thickasxthieves thickasxthieves is offline
Send a message via AIM to thickasxthieves
I'm going to be doing a reseal myself I just ordered valve cover gaskets and washers, crank seal, cam seals, but not head gaskets... do the head gaskets have to be done or can i reuse the old ones or will head gaskets not even come into play. please help a noob
94 Emerald LS w/ awd 4.44 swap 199xxx daily driver
Stage 2 ECUTune chip, 370cc injectors, ECUTune valve body and TCU, solid rubber motor mounts from a forester, outlaw phenolic spacers, COBBTuning lightweight blue crank pulley, Bontragerworks 22mm rear sway bar & endlinks, StrongFlex poly front sway bar bushings, Powergrid adjustable front sway bar endlinks, 17" MOMO CORSE RPM wheels w/ Toyo Proxes4 225/45, drilled/slotted rotors f/r, stainless lines, ceramic pads, Blue silicone radiator hoses, power mode switch, gold jdm hood badge, 20% tint all around, Hella optilux xtreme yellow fog bulbs
parts waiting to go on car: the rest of the strongflex polyurethane suspension bushing set
Old 02-02-2010, 11:40 AM
umm, why not do the head gaskets??? you're already pulling the motor to do the work I assume. The HG that are original are prone to fail sometime soon just for the simple fact of the age of them. Avoid the headaches later on, get a full reseal kit, and replace everything at once. The full reseal kit is only about $260 shipped to your door.
Old 02-02-2010, 11:50 AM
Do the head gaskets have to be done or can i reuse the old ones or will head gaskets not even come into play. please help a noob
Definitely do the head gaskets! This is the time to do them and you should never have to worry about them failing again. It is more a function of age than mileage (I had to repace mine in my 96 with only 128,000 miles)
New HG's come with the reseal kit anyway, so use them. I GUARANTEE that you will never be able to reuse a head gasket that is 16 years old and 175,000 miles of use.
The P/N for the gasket and reseal kit is 10105AA060
Old 02-02-2010, 12:00 PM
k i guess ill just order some up then. and no i wasnt planning on pulling the engine, unless its impossible to do all this without pullin it.
Old 02-02-2010, 12:34 PM
The vast majority of the rubber seals (valve covers, cam, front main) can be replaced with the engine in the car. To replace the rear main seal you must pull either the tranny or the engine. If you're going to be pulling the motor do the head gaskets. It's basically impossible to do them in the car, and the SVX is a relatively easy vehicle to yank the motor out of.
Old 02-21-2010, 10:49 PM
aust92pearl aust92pearl is offline
reseal kit arrived today
thankyou nate
Old 02-27-2010, 07:24 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Ill be finally doing my valve cover gaskets in about a week, and reading this thread confirmed that they want WAY too much for the seals for the mounting bolts.
My question is: Can somebody tell me the approximate dimensions (diameter, center hole diameter, thickness) so that I can try to find them from some other source than Chaplins Subaru/1stSubaruParts/dealer etc etc. I may be able to source them from the local parts or hardware stores. This of course, is if they aren't too form fitted to be possibly substituted
