Old 11-12-2009, 10:27 PM
subiemech85 subiemech85 is offline
anytime foglights!
ground red wire with green stripe
can be easily done by unplugging the relay, attaching wire with line splice, reconnect relay
relay is above fuse box
refer to this link if you want to do it the hard way
be sure to connect a switch to ground for the new wire for convenience of use
your fogs will work as normal with the switch I hope you add in the open position
if you want to just hold the wire to bare metal, as it may be interesting to do this while driving
"Some work occaisionally is fine, but I bought the car for the road, not for the garage. " BoxerFanatic
click here for fuelly mpg info
