#61
Re: 11:1 CR Race/Street Engine build
Update!
Cams from Web are IN! 740cc injectors are on their way Meziere water pump and fitting are on their way Silicone hoses will be ordered Monday 1 5/8" Tubing for the headers is on its way, thermal coating after completion Hydra will be ordered Monday More to come! ![]() Tom Last edited by TomsSVX; 08-09-2009 at 05:05 PM. |
#62
Well, got a good deal of parts here but without have the heads done, I have been spinning my wheels.
RallyBob had not been able to get to the heads before so I have ported and polished them myself. I had been to Bob's shop and he gave me a tutorial on how he ports the heads in regard to the dogleg exhaust port. WIth that knowledge in mind, I was able to port and polish them in about 14hrs ![]() That being said, the heads will be off to the machine shop this week and should be assembled this upcomming weekend if I can find the time. Once the valves and all other components are loaded I can then select the shims I will need and order them accordingly. Long block is finally coming together. I have also prepped a good deal of parts that will be sent off to powder. In the process I have decided to cut up a water pass-over pipe. The passage through is MUCH smaller than I ever imagined. I will be fabricating a roof ontop of the X-over to increase the X-section and allow for more water to pass through with less restriction. This along with the other modifications to the cooling system should be a good start at tackling the overheating issues with the EG33 when spun to higher than stock RPMS. More to come, sorry I am not a picture taker, not until the tires are spinning ![]() ![]() Tom |
#63
Danny 1994 Silver SVX in hybernation, awaiting for the monsterous awakening (Lebanon) ![]() 1967 Mercedes-Benz 250SL Euro Specs, Hard/Softtop, White/Red. Under Complete Restoration ![]() 2013 Mercedes-Benz SL350 Euro Specs, White/Red. Mint... Another step into SL Collection. ![]() |
#64
YT,
Got your voicemail! Told you that cross over wasn't flowing much ![]() I'll have to have you check out the heads I ported/polished when you come down for the rims/tires. -Bill (Vicodin is your friend!) Quote:
#65
Just when I thought I was done with the Die Grinder... I remember I have to clearance the bucket sleeves... Damn these lobes are huge!!
![]() ![]() Tom |
#66
Check BOTH sides of the bucket and the sides of the head, and just for laughs check the clearance to the underside of the valve cover with some clay. Remember when everything gets hot, dimensions grow...
#67
Tom |
#68
Pics! pics!
#69
Get into your Corolla of death and drive down to the shop and take a look for yourself
Tom |
#70
Fixed! .....
#71
OK got the RH head lash measurements done. Problem is, the shims I originally wanted to order (2.5 shims) do not come in small enough thickness (less than 2.0mm). Does anyone know where I can find some 26mm wide shims??
Tom |
#72
#73
I know a guy who knows a guy...but you've probably already called him
Maximum acceleration, maximum lateral g-force...it can be done, it just takes time and $$$ |
#74
Tom |
#75
YT,
Did a little checking. Can you confirm that you'll want shims that have a Rockwell harness of 45 or greater? -Bill
