#46
Re: How To Do the Bosch Relay Mod???
Keith,
Such a definitive statement requires proof. ![]() Cheers, Trevor. ![]()
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() |
#47
This paper may bring some clarity to the whole Bosch Relay Mod story. Take a look at Figure 6!
Enjoy! www.aeroelectric.com/articles/strtctr.pdf
92 Pearl White LS-L 215,000 KM smallcar 5MT, Ecutune 1.5, SS brake lines, svxfiles 6000K HIDs, $15/15 min mod, $20/20 min mod, Front and Rear Energy Swaybar Bushings, Bosch Relay Mod 92 Liquid Silver LS-L 127,000 KM |
#48
![]() Keith ![]() |
#49
Would it alleviate your concern to observe that the "fault" you refer to is not a part in any way to the mod Bosch circuit. Neither of us actually know where the "fault" is so proof, a 2 way street, would be a tough one for either of us. I no longer care where the fault lies because the Bosch relay works like a dream... not the nightmare so many of us were and many more are having before the Bosch Relay! When you get the click yourself ![]() ![]() Cheers back! ![]() Keith ![]() |
#50
The coil resistance is the specific item involved in the problem. One end of the coil has always been grounded, as it must be for the relay to operate. This is not a new feature. Please confine yourself to comments regarding that which you understand. ![]() You are not wise enough to pre determine my actions. I will never leave an existing fault in place and use a stop gap measure as a means of overcoming a problem. I will locate the problem, analyse the cause and fix it. I and am quite sure that I have the skill to do so. ![]() Even so, I would consider fitting a slave relay, if the fault was clearly evident, as being due to excessive current. ![]()
#51
![]() Harvey.
#52
#53
![]() ![]() ![]() Your friend. Harvey.
#54
Ah yes, indeed it is so. Once again you have wrongly advised members. It is ongoing, and as always you side step.
![]() Friend of the truthful. Trevor.
#55
![]() Maybe you would be so kind, as to point out the parts, where I am wrong. ![]() We would not want the members to find it confusing. ![]() As always, Harvey. ![]()
#56
Because it may assist anyone interested, I will correct the error, in spite of baited sarcasm.
![]() The SVX starter assembly is not complicated and is as exactly illustrated in the manuals. There is a clear difference between this, and a more ambitious system, claimed as applying in respect of the SVX. It is necessary to correctly interpret the two applicable drawings. This is where confusion has occurred. ![]() The simple arrangement as per the manuals and used in the SVX, has two integral coils, or a single tapped coil, forming a series circuit, with each separate inductance arranged in the same order of polarity. The pull in section is likely to be wound in heavier gauge wire, in order to carry the more substantial current involved. In order for the claimed more complicated arrangement to work, two coils must be provided, but these can be wound on the same former. The two coils facilitate connection in opposing polarity. The drawing previously submitted is not correct and wrongly portrays the electrical function described. ![]() The valuable site kindly submitted, clearly outlines the different arrangements involved. It will prove of great assistance to any members dealing with the SVX starter. ![]()
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() Last edited by Trevor; 08-12-2009 at 04:01 AM. |
#57
If this is the drawings, where " This is where confusion has occurred, would you point out where "is not correct and wrongly portrays the electrical function described" so that I can correct it, thanks. http://www.subaru-svx.net/forum/show...9&postcount=83 Pursuing Technical Excellence. Harvey. ![]()
#58
Your drawing illustrating the system described, clearly illustrated a tapped coil. Such a coil would render the functions you described, inoperative. ![]()
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() Last edited by Trevor; 08-12-2009 at 10:58 PM. Reason: Fixed Quotation marks. |
#59
I know 2 wrongs don't make a right, but neither does one wrong make a right!
Actually that statement is meaningless, like some of the attempts that to prove that everyone else is wrong on this subject. We should all be able to learn from each other and if some can't, I think that tells a world about the person that is unable to. When you come on demanding proof and can never provide proof for whatever your contention is, you need to do some real deep soul searching. Now... Tell me that I am wrong about this! Keith ![]() Incidentally, the Bosch relay comes new in a little box that actually does not have a ground anywhere on the box or the relay that is in the box. Anyone that says the Bosch relay is always grounded is... WRONG! ![]() |
#60
I will wait right here for your explanation, and no proof is required! Seeing what you come up with will be reward enough! Keith ![]() |
