Old 09-24-2002, 01:52 PM
fourtaylor
Question Removing lower outside door panel
Hello - does any one have any suggestions on removing the outside door panel? I want to do some R&R on the door and can not figure out how to get the thing off. I could pull harder but I do not want to destroy it in the process of removing it.
Also, where could I purchase some replacement pins for re-installing the panel when I am done.
Thanks. much in advance.
Chris Taylor
92 Silver/Black....
Old 09-24-2002, 05:56 PM
wawazat??'s Avatar
wawazat?? wawazat?? is offline
Yeah, I'm still around
You're not going to like this
the best way is to remove the inner panel and then reomove the clips from inside the cavity.
Good luck
Down to none
Old 09-24-2002, 06:39 PM
nubs's Avatar
nubs nubs is offline
Multiple Suby Owner
Re: You're not going to like this
Good luck
Not only is it the best way,it is the only way.
There are also some nuts in there that have to be removed along with the clips.
Old 09-24-2002, 09:44 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Please avoid phrases like this, when posting. Some warped mind could possibly use them to twist the thread into something tawdry.
Randy Johnson
Mike Davis -- at Reading VI
Old 09-24-2002, 10:54 PM
Green1995SVX
Oh the mental images that those comments just generated.... <sigh>
Mike
Old 09-25-2002, 09:07 AM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Significant Technical Input
I don't think of it as tawdry. Actually it reminds me of a perfectly normal marriage.
Old 09-25-2002, 09:12 AM
fourtaylor
Thanks guys....I knew there must be something more to it. I will give it a whirl tonight.
Chris.
