Old 07-23-2009, 04:13 PM
aust92pearl aust92pearl is offline
vacuum leak somewhere ??
ive worked out the squealing noise i posted about a few weeks ago is its a vacuum leak from somewhere under the intake and throttle body on really cold mornings its quite loud and once it warms up it stops until i touch the throttle and under any amount of throttle i can hear it in between the block and the intake but while the car is not moving it doesn't squeal just sounds like air escaping or getting sucked in my dad and i tried to pull the intake off the top of the block to find it but couldn't get it completely off and failed to find the leaking hose .it doesnt affect the idle or while its driving just makes a really weird sound sorta like a constantly winding turbo and as i come to a stop i can hear it slow down and stop as the engine goes back to idle it sounds similar to a loose squealing belt but its not
any ideas what its coming from ?
im going to buy new vacumm hoses soon and replace them all as they are all hard n stiff should i buy new molded breather hoses or just use normal hose and cable tie it in place
Old 07-23-2009, 05:45 PM
alia176 alia176 is offline
Send a message via Yahoo to alia176
Re: vacuum leak somewhere ??
I removed the intake manifold today and my goodness, are there lots of vacuum hoses Lots of them are brittle while others are still very pliable. Can we buy bulk metric hoses from somewhere or does Subaru sells them?
If it ain't broken it, doesn't have enough features!!!
'92 SVX LSL
'03 4Runner
'96 FZJ80 Landcruiser
'90 Mercedes 300E
Old 07-23-2009, 05:49 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Mine makes a similar sound when slightly revving the engine, which stops immediately after the engine returns to idle. Im not sure if its the same sound (sucking air kind of whistle), but mine has done it for a long time but its not a vacuum leak, ive gone over it meticulously.
Old 07-23-2009, 08:17 PM
michael's Avatar
michael michael is offline
What Potholes ???
Look at your IRIS check valve it's an inline valve between the PS pump and the alternator. Spray a little carb cleaner on it to see if it changes the idle. Do a search if you can't find it.
Wanted: Steering Wheel
