Old 07-10-2009, 02:47 PM
SomethingElse's Avatar
word words wording
Arrow Rebuilt Power Steering Pump
Rebuilt means.. I clean, disassemble, Inspect components for wear, refurbish/replace worn internal parts as needed, replace every single o-ring, the bearing, spring, and front seal, using all genuine subaru parts.
Im asking $110 shipped to the lower 48 states plus a $40 core charge. If you have a rebuild-able core I will refund $40 back to you once I get your old one, dismantle and inspect it. If you want to send paypal please click on the tab labeled personal and send the payment as a gift, paypal does not charge fees for a gift. My paypal address is kulaid2@hotmail.com The total sent should be $150.
CORES MUST BE SENT BACK WITHIN 30 DAYS!
It is vital that the cores be good. If the case has too much wear, the shaft has deep grooves worn in it, the pressure relive valve is frozen or worn (valve not available separate from Subaru) I can not issue a full core credit. I have to set the standards high on the cores to maintain quality.
The power steering system must also be COMPLETELY flushed! These pumps do not like metal (or sand) getting inside them, It causes fail.
Eric
Old 07-10-2009, 03:53 PM
BoxerFanatic's Avatar
Re: Rebuilt Power Steering Pump
Good to know...
-filed for future reference. Thanks for offering a good service.
"What you plan, and what actually happens ain't exactly ever been similar..."
1992 Claret SVX. Rescued from certain destruction, and still on the road, where it belongs. Waiting for a bit of a makeover, when I can afford it.
2005 Garnet Red Pearl Legacy GT Limited 5-speed. - The late great Subaru sport touring sedan.
1999 Classic Red Miata, Preferred equipment package 5-speed. Fun, fun, fun, in the Sun, sun, sun.
Old 07-10-2009, 05:40 PM
Sounds good. Nice to know this is out there if I ever need it.
Old 07-10-2009, 07:24 PM
word words wording
Here are a couple of the internal o-rings..and the bearing...the big one had a crack on the bottom of it before I even touched it. When they break, pressurized fluid leaks internally and externally. I broke the small one to show how brittle they get.
Some people will swear the reservior o-ring will stop it from leaking. Keep in mind all of these O-rings go through the same dramatic temperature changes.
Eric
Old 07-11-2009, 10:58 AM
Crazypolo95 Crazypolo95 is offline
95pologreen
Send a message via AIM to Crazypolo95
About two weeks ago I order an the rebuilt power strewing pump form somethingelse and I wanted to said wow!! My old pump was about to gave out on me but with this new pump the car tunes and feels allot smoother then before.I'll gave you ups for how much different the new pump made an big inpack on the car.
Originally Posted by SomethingElse View Post
Rebuilt means.. I clean, dissasemble, replace every single o-ring, the bearing, spring, and front seal, using all genuine subaru parts.
Im asking $155 shipped to the lower 48 states. If you have a rebuildable core I will refund $40 back to you once I get your old one, dismantle and inspect it.
Ive already sold 2 reman units and have been running 3 on my own/wifes car for nearly a year with no problems. shoot me a p.m. if interested. I currently have 2 units ready to go.
Old 07-11-2009, 11:49 AM
I don't know if you are interested in doing a How-To with pictures, but that would be good. Remember that some members would rather just buy from you than do it themselves, but others would like to do it themselves so they learn more about our cars.
Old 07-11-2009, 12:44 PM
michael's Avatar
michael michael is offline
What Potholes ???
+1
Wanted: Steering Wheel
Old 07-11-2009, 01:20 PM
Yes that would be great, you can also learn a lot from the diagram if you can get it (subaruparts?)
Old 07-12-2009, 06:20 AM
michael's Avatar
What Potholes ???
Does it look like this?
Old 07-12-2009, 08:25 AM
I guess this is his setup without the cracked cover.
Old 07-12-2009, 01:54 PM
word words wording
Not really interested in the tedious task, but Ill do just about anything to keep as many SVX es es in good running order
Currently, I do not have any cores. Ill do a write up with pics when im rebuilding "crazypolo95"s.
Thats ubur funny
Eric
Old 07-12-2009, 04:36 PM
If you get the pictures and a write up, I can get it finalized.
Old 07-28-2009, 05:01 AM
word words wording
Sorry Guys Im still working on this how-to but the past few weeks either I was the only tech on duty and/or we have been overbooked...I guess its good to be busy
Eric
Old 07-28-2009, 05:06 AM
Eric,
I may need one of these done in the near future. I have a couple cores. Additionally, I have a seized pump which I was just going to throw away. Would it help you to have it?
Old 07-28-2009, 02:27 PM
word words wording
Eric,
Yes it would help to have the seized one. If a member sends me a bad core, and I can use parts from a donated core, I can still issue a core credit to that member.
Eric
