Old 06-23-2009, 03:24 AM
jdigitty88 jdigitty88 is offline
need help
my car wont start in the morning i have be on the gas for a while and ride the starter but after the first time it starts the whole day with no proplem any ideas thankz
Old 06-23-2009, 05:25 AM
Green1995SVX's Avatar
Re: need help
My first guess is Coolant Temp Sensor.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 06-23-2009, 05:23 PM
Re: need help
okay well wheres that at and thankz
Old 06-23-2009, 09:55 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: need help
Looking from the drivers side, under the hood, its the sensor directly below where the throttle body connects to the intake manifold. It has 2 wires coming out of it. If you want more detail on location/testing, and diagnosing your problem.... download the SVX service manual, the link is directly below in my signature. It includes flow charts to help eliminate the most likely causes in a step by step procedure.
Luckily ther coolant temp sensor is easy to test (with a multimeter) and relatively inexpensive. Dont forget to download the service manual...its indespensible for anyone who does their own work. Good luck!
Old 06-24-2009, 09:59 AM
Re: need help
thankz ill take a look wen i get of duty
Old 06-27-2009, 05:23 PM
Re: need help
okay i got code 34 would that be the reason i would only do that in the morning thankz for the help
Old 06-27-2009, 09:10 PM
Re: need help
34 EGR solenoid valve EGR solenoid valve inoperative.
I have no idea if/how this would effect starting.
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
Old 06-28-2009, 01:32 PM
Re: need help
okay well cleaned it put it back and cleared the code drove it and cel came back now it says code 32 o2 sensor any ideas anyone would this be why its hard to start in the morning
Old 06-28-2009, 03:50 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: need help
Did you or didnt you check the coolant temperature sensor? The o2 code shouldnt have any effect on starting, but the CTS would. If you removed and reinstalled the EGR solenoid.... then testing the CTS should be a breeze.
Old 06-28-2009, 04:05 PM
Re: need help
yea but wasnt sure what the reading should be when i tested it so yea im lost
Old 06-28-2009, 07:51 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: need help
The specifications for correct resistance values are in the manual, as is a flow chart for your problem.....
Old 06-29-2009, 04:53 PM
Re: need help
okay check this out i cleared the codes and did the relay mod and powerwashed the motor now the car starts like a champ wtf i dont no but my spedo stoped working oh well i can live with that thankz for all yall help
