OBD1 upgrade to OBD2?
Has anyone done it? Is it possible? If so, please note if you can, what the major changes have to be?
:..Miharu..:(1994) Laguna Blue SVX 170k. MODs: Beat to shjt. :..Fey..:2005 World Rally Blue Impreza WRX 80k and rising. MODs: Lowering springs, 22mm sway bars. SS brake lines. |
Re: OBD1 upgrade to OBD2?
Why
not sure why u would want this... doesnt ECUtunes chips only work with OBDI? As well I thought the hydra for the SVX was only OBDI as well could be wrong on that
1992 SVX: JDM STI short geared 6-speed swap, COBB short shifter, slotted cross drilled rotors, Smallcar Clear headlight lenses, 1997 Grill. 1992 RHD WRX: EJ20G, 16G, Cusco Coilovers, Wilwood 4pot/2pot brakes, Defi Genome 60mm gauges, Exotic speed downpipe, 3.5" A'PEXi spec GT catback |
This would be an extensive modification, several of wiring harness are different, there are more oxygen sensors, and a few other things
2007 GS 450h-Active Stabilizer/Radar cruise 1994 L Blue 3.70 VTD ASE Master Automobile ASE Advanced Level Specialist Toyota Master Diagnostic Technician (former life) |
You would probably have to completely remove the wiring harness from the OBI car and take the wiring harness from an OBDII car and put it in. Its a ton of work as that would involve removing the whole dash as well as basically the whole HVAC system behind it.
I would have to agree with Sov13t and ask why you would want to do this. The OBDI system can be self diagnosed while the OBDII system you need to have a cpu reader, OBDI is able to be "chipped" while the OBDII is not(at least right now). |
OBDI is perfered if your doing any mods to your car. The ECUtune chips dont work, the Hydra just recently became compatible with it (I think?). One of the reasons I sold my 96 and bought a 94 was to go to OBDI
