Old 04-27-2009, 05:05 PM
US to CDN SVX's Avatar
US to CDN SVX US to CDN SVX is offline
SVX Voyeur
Front end whine
Hey Guys,
*** Strange problem has surfaced. Last week I started to get a whine coming from the front. It is only on acceleration and goes quite on decel. I thought it might be my tires so I rotated them as it has almost a radial hum but high pitch. It does not very with RPM only gets louder with speed. Kicks in after 25Mph's Would this mean a front diff is whining? Anyone have this before from the front? I only have 94,000 Miles on her, do not drive her hard, fluids all changed. I don't think it would be wheel bearings. Only things left are the diff,tranny,cv I had a new tranny at 50,000 miles. Things to check before Subaru tells me what it is for $125 ?
1992 SVX LSL Peacock 94,000Miles
1981 VW Westfalia 166,000Miles
1995 Volvo 850 Wagon GLE 174,000Miles
1981 FIAT Spider 120,000Miles
50% Boxer
Old 04-27-2009, 11:48 PM
SVX Voyeur
Re: Front end whine
Sorry guys. This should have been under the tech section. I am a little rusty.
50% Boxer
Old 04-28-2009, 05:40 AM
dcarrb dcarrb is offline
Re: Front end whine
Originally Posted by US to CDN SVX View Post
Hey Guys,
That's the first thing I'd check.
dcb
Old 04-28-2009, 06:32 AM
Green1995SVX's Avatar
Re: Front end whine
I'd be more apt to think it's the front differential.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 04-28-2009, 04:08 PM
PaulDexler PaulDexler is offline
Re: Front end whine
It is the front diff. I have it the other way around, it whines on the overrun, but not on acceleration. The place that rebuilt the tranny last year offered a warranty on it, but when I went in to take them up on it, the guy that worked on my car was no longer there, nor was the guy who wrote it up, so they blew me off. And I can't afford a new factory ring and pinion ($1,800) so I'm treating the car gently and living with it.
Paul
The great white fleet:
'91 Alfa Romeo 164L 5-speed
'92 Subaru SVX LSL
'93 Mercury (Aussie) Capri
Old 04-28-2009, 04:50 PM
Wikedjuggalo's Avatar
Rebuilding
Re: Front end whine
I wouldn't jump on it being the diff. My front diff made more of a clicking noise that was linked to the RPM. I would describe it as card hitting a bicycle spoke. It increased with revolutions.
Old 04-28-2009, 06:51 PM
Re: Front end whine
There are several components in the front differential which could fail. They could all cause a different noise.
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
Old 04-28-2009, 07:20 PM
Rebuilding
Re: Front end whine
Was merely my experience the pinion gear (I believe) went out in mine.
Old 04-28-2009, 07:25 PM
Re: Front end whine
I know its a completely different vehicle but when the rear diff was going out on our 89 Astro van(RWD) it did exactly what you are describing. It did this at about 160,000 miles though from wear so I'm not sure why yours would be doing this already unless it either was run low on fluid, or if a seal went bad and trans fluid is seaping in.
Old 04-29-2009, 12:07 AM
SVX Voyeur
Re: Front end whine
Well I guess I will have to leave it to a Subie mechanic to diagnose. I did take it to a tire shop today just to confirm it was not the tires.
I do have the original bearings on the car. When I steer hard side to side there is no change which makes me think it is the diff.
I remember one cold morning this winter it made a hell of a racket then then went away. Today it was a warmer day, 70ish and it was a little quiter
50% Boxer
Old 04-29-2009, 01:51 AM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
Re: Front end whine
did u have a new front diff when you had ur new tranny?
or is that a rebuilt one?
Check the front diff fluid condition. You can probably tell more info.
How bad is the whine? Change the fluid might help.
If it's the front diff,
It'd eventually get louder and louder, your car will stop...
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Re: Front end whine
It could possibly be a front wheel bearing, but it is likely to prove to be a bearing in the front diff.
I trust you will get her sorted.
Old 04-29-2009, 08:41 AM
Re: Front end whine
Happy Birthday, by the way!
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
Old 05-01-2009, 08:42 PM
SVX Voyeur
Re: Front end whine
Thanks for the advice and B-day wishes. I have parked it till I take it over to a mechanic as the weather has been nice on the West Coast. I will let you know the diagnosis.
Cheers
50% Boxer
Old 05-01-2009, 09:32 PM
Re: Front end whine
Paul
Your diff was not setup properly. You pinion was digging too deep and I am sure have worn the teeth and will continue to do so.
Your pinion bearing failed, not the gear itself, that is why the noise was so different.
Cheers
Good luck but you will be in for a new gearset with new bearings and hopefully seals while you are at it.
