Old 03-04-2009, 07:58 AM
jdmlambo jdmlambo is offline
Question Seatbelt Trouble Code 25 Help!!
This morning my seatbelts were working fine..both of them..i dropped my girlfriend off and it opened an retracted properly.
im driving home and i noticed the seatbelt light flashing.... i pull over and open the driver door...works fine.... Next i try the passenger and it stays put in the closed position...
check the codes when i get home and i get..
#25 Front and rear limit switches on passenger side are OFF
just askin too see if anyone knows anything...any tips...
just hoping someones been here before so i dont have to go nuts testing the circuit.... thanks for any help...
Old 03-04-2009, 08:05 AM
Re: Seatbelt Trouble Code 25 Help!!
ok........ i went out to take a look at it right after the post...... just wanted to manually crank it back to see if i could trigger the limit switch... And what do ya know....the damn things working....
i just want to know if anyone knows what the heck that is all about... maybe the module is on the way out?? i do live in Toronto and its been around 5 Fahrenheit for a week...everything is frozen...but has never ever been a problem... i dont know.....works now....im happy..
Old 03-04-2009, 08:54 AM
Cynic's Avatar
Cynic Cynic is offline
My driver's seatbelt sometimes doesn't retract back after I get in and shut the door. If I open and shut the passenger door, it goes into its correct position?!
Has been doing this, off and on, for a year or so. Never got a warning code? Just figured its a gremlin in my car?
Cyn
92 Ebony Pearl LS-L 199,000K New Tranny (my DD)
89 Chevy Sprint (for when my baby's in the shop)
05 Mazda 3 (Hubby's DD)
"You win some, you lose some, you wreak some." Dale Earnhardt
Old 03-04-2009, 12:01 PM
Maxo's Avatar
Maxo Maxo is offline
My seat belts have issues as well and I've found that they seem to malfunction mostly during the winter.
When the temps drop below 0° they almost always start acting up. As soon as the interior of the car gets toasty my flashing seat belt light will usually turn off and the seat belts will function normally. Of course this may not apply to you depending on where you live.
I often think about just converting to the newer style but I'm just not that ambitious. I would if they completey stopped working though.
