Old 02-23-2009, 11:19 AM
NiftySVX NiftySVX is offline
Torque converter lockup temp
I recently relocated my sending unit for my trans temp gauge to the oil pan. It shows 97F when the converter locks up, and it's not off more than 10%, I can confirm it with a temp gun. Where is everyone getting the spec for lockup prohibit @ <150F?
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 02-23-2009, 07:04 PM
immortal_suby's Avatar
Thread Killah
Re: Torque converter lockup temp
My remote filter/temp gauges always shows right around 150 at lockup. Have them on 2 different svx's but the same gauge mfg. Maybe the output oil is hotter than the pan oil temp?
Locker Link
2015 BRZ Limited 6MT
Old 02-23-2009, 07:22 PM
yeah it is much hotter. I'm thinking the actual temp in the pan is 100F for lockup. Mine used to show 140 when it was on the remote mount.
Old 02-23-2009, 08:28 PM
140* in the pan. Some lock before that.... never did fig. that one
Old 02-24-2009, 09:48 AM
kcbsvx's Avatar
kcbsvx kcbsvx is offline
Now down to only ONE!
Tom-
Mine locks up at an indicated 96-99* on the gauge you installed. The temp sender is on the remote filter just outside and downstream of the trans, right?
Christian
Christian-
96 SVX Lsi #821, Bordeaux Pearl, 4.44 98 Legacy Trans, Trans Resistor Mod, Dakota Digital Trans Temp Gauge on A-Pillar Pod (awesome), B&M Trans Cooler in Driver's Wheel Well, External Spin-on Trans Filter, Synthetic Fluids in Trans and Diffs, 17x7.5 Primax 695 Rims, Alcyone Rear Panel, Svxfiles' 5000 k HIDs, Clear Headlights, "BOXER6" License Plate, Hard Wired Radar Detector, 94 Power Up Window Switch, Motor Resealed, new Coil Packs, new NGK Iridium Plugs, PVC Valve, Drilled and Slotted Rotors, Gloss Black Calipers and Rotors, EBC Greenstuff Pads, SS Brake Lines, Superb TomsSVX Cat Back Exhaust... SS Resonator, Flowmaster 80 Muffler, Magnaflow Quad SS Tips, Poly Swaybar Bushings, Endlink Mod, Rear Subframe Bushing Mod. Feels great and sounds even better. Thanks to AWD, LLC.
2003 Outback llb H6 3.0 Titanium Pearl- "BOXERR" Mostly Stock
1995 Bmw 325i Conv. Calypso Red- "RBOXER" Modest Mods
2004 Sea Doo Sportster 4-tec 15' Jet Boat, 1494cc, 1454#, 155 HP= <10#/HP Stock
Old 02-24-2009, 11:34 AM
I need to get ahold of a select monitor so i can just compare it mysef. 100 seems more likely, but i feel like I remember reading the spec myself and thinking it seemed high.
Old 02-24-2009, 08:22 PM
liamrh's Avatar
liamrh liamrh is offline
I would like to know also. I have been negotiating for a special thermostatically regulated trans fluid bypass and they currently have one that is starts to open at 160 and one at 125. I figured the 125 was to low though.
Old 02-24-2009, 09:16 PM
Originally Posted by kcbsvx View Post
Tom-
Christian
Yes, that car is one of the odd-balls that locks sooner
