Old 02-04-2009, 03:21 PM
newkid17's Avatar
newkid17 newkid17 is offline
Send a message via AIM to newkid17 Send a message via Yahoo to newkid17
tranny wont shift?
ok so i just got done with my front diff. and took it out today and it wont shift out of first? i have not looked at it to see if any connectors were unpluged or not but i would not think so. when i get home i will check it out but is there anything else i could check while im at it?
Old 02-04-2009, 03:37 PM
oab_au oab_au is offline
Re: tranny wont shift?
Do you have reverse?
Did you remove the valve body and forget to reconnect the manual valve into the shift lever that comes through the side of the box.?
One Arm Bloke.
Tell it like it is!
Old 02-04-2009, 03:50 PM
newkid17's Avatar
yes i had reverse, and i had the valve body off, what is the mannual valve, i do remember that there was a connector sticking up, it was a mid sized one that is like a lime green on the inside....???
Old 02-04-2009, 04:06 PM
If you have forward and reverse, then the manual valve is connected ok. This is the valve at the top middle of the pic
Is this where the connector is or out side the box?
One Arm Bloke.
Tell it like it is!
Old 02-04-2009, 04:17 PM
newkid17's Avatar
is it the little bar thing running across the top right above the filter? i did replace the filter.....
Old 02-04-2009, 05:06 PM
Yes that is the manual valve, it selects 1st and reverse, but if you have both of these gears, the valve is connected.
The other thing that can prevent it from shifting is no speed sensor signal.
One Arm Bloke.
Tell it like it is!
Old 02-04-2009, 05:51 PM
newkid17's Avatar
well there is a connector under the hood, it is right under the intake manifold and on the inside of the connector it is green????? i can not find anywhere where it goes.
Old 02-04-2009, 07:42 PM
newkid17's Avatar
i found out where that connector goes, and it connects to a speed sensor? on the front diff. right behind the dipstick...but i kinda have a problem the sensor that is in the new front diff. that i just put in the car does not have a connector piece, and the one on my old front diff. does, is there any way in can combine the two? and would this make it now want to shift out of first?
Old 02-04-2009, 08:14 PM
Yes no speed sensor no change. To solve the different sensor question, we need to ask a LHD man like OT.
One Arm Bloke.
Tell it like it is!
Old 02-04-2009, 08:52 PM
log1call log1call is offline
I think it would take both speed sensors to be defective for there to be no gears. Even then wouldn't it change if it got to red line?
Heres what a manual says about the older trans...
If shift solenoids #1 or #2 malfunction, the TCU
deactivates the other. This results in either 3rd gear
or Reverse (when selected).
If duty solenoid “A” fails, line pressure goes to
maximum.
If duty solenoid “B” fails, the torque converter lock-up
will not occur.
If shift solenoid #3 malfunctions, the overrunning clutch
is always “ON” and there will be engine braking during
deceleration.
If duty solenoid “C” should fail, the 4WD control will be
set to maximum and the rear wheels will always be
Could it be that it has reverse and third Perhaps?
Old 02-04-2009, 09:08 PM
newkid17's Avatar
no it is def. reverse and first because i can only go about 10 mph... so i cant be 3rd.... i did check the big fat wireing harness that connects from the tranny and it was not snapped in all the way.... i didnt take it for a drive after i snapped it in but i still need that speed sensor reguardless.... i just need to get this thing fixed.... it has been nothing but trouble, because i was doing it on the ground in like 10 degree weather
Old 02-04-2009, 10:18 PM
There is a difference in the two types of speed sensors, the SVX uses a Hall Effect unit, three wires.
The other boxs use an inductive unit, two wires.
You have to change the sensors over, to use the Hall Effect one.
One Arm Bloke.
Tell it like it is!
Old 02-05-2009, 11:30 AM
newkid17's Avatar
ok so i talked to a subaru mechanic today and he said that where i took that sensor out at,on the front diff, there should be like a washer thing in there, he said i can pull that out and the speed sensor off my svx front diff. should screw right in to the new front diff. is this right?
and i was thinking that this is the problem for it not shifting because the TCU has to see some sort of speed to be able to shift i would think?!?!
Old 02-05-2009, 03:02 PM
That seems to be how it is changed over. Yes it has to have the speed sensor signal, to change gears.
One Arm Bloke.
Tell it like it is!
Old 02-06-2009, 01:33 PM
newkid17's Avatar
well i got it changed over today but now i have a transmission hose that is leaking. so now i have to fix that before i take it for a drive i hope that this time it will go out of 1st gear........
