Water in trunk
I have noticed water in my trunk in the well with the spare tire. Also noticed condensation in the tail lights. Anyone have this problem and hopefully a solution? Is there a seal around the trunk lid that could be causing this? No moisture that I can tell inside car. Thanks.
Never mind. found it in forum Last edited by gwomack; 12-29-2008 at 07:18 AM. Reason: Found it in forum |
Re: Water in trunk
I've read in the previous threads that they're common with our SVX's. Mine does the same thing, condensation in the tailights seems to dissapear when weather changes. You could keep one of the 2 rubber drain plugs off, or open for water to drain in the spare tire area.
92 LS liquid silver ---> pics here:http://s36.photobucket.com/albums/e8...VX%20LS%20AWD/ |
Re: Water in trunk
Mine does this as well. I seem to remember a post a long time ago mentioning a drain from the sunroof gets clogged and causes this. I may be way off...
Many years ago I drilled small holes in the bottom of my tail lights to "vent" the moisture. It has worked well. |
Re: Water in trunk
As for the drilling, you think there is anything less extreem that can be done? Like adding silicone or additional seals?
1992 Pearl White LS-L "Ruslana" #4946 - 180k on body, 95k on engine. Mods: ECU bead crush, 15 min mod, 20 min mod, drilled/slotted rotors & Axxis ceramic brakes, SS lines, 17" Evoke F1 wheels, XS-HF137 Sony Xplod speakers, 6000k HID's (lows & fogs), resistor mod, 1˝" Sleek Spoiler mod, custom exhaust by svxfiles, '02 WRX aluminum racing radiator by svxfiles, Summit Racing 400# x 300# springs w/ Koni's by svxfiles, ClassGlass fiberglass hood /w scoop, Nevin's rear sway bar, '97 grille, phenolic spacers, custom LED interior lighting, custom paint. †"War doesn't determine who is right, only who is left"† Work to be done: Tinted windows, clear/LED tail lights, tailbar mod, "Power Mode" mod, Supertone horns, clear corners & headlight lenses, 2 pc splitters or custom bumper, Alcyone side skirts, TruSpeed Stage III SVX Intake, Hydra, 4.44 tranny swap, JDM auto folding side mirrors, engine rebuild, super charger, STi seats, bone leather interior /w SVX emblem, dash overhaul, SVX decals, paint (stock color). Total cost?: 22k ![]() |
Ah... I knew it caused flooding somewhere... The holes I drilled were in the bottoms of the light housing. It can't be seen outside the car. I took the light housing out and used a very small drill bit. Gosh I did this like 10 years ago. Immediate fix.
Re: Water in trunk
I took the driver's side trunk side panel off and found the drain hose for the radio antenna disconnected. Also found an empty bottle of vodka.
![]() Gene
Re: Water in trunk
Re: Water in trunk
![]() Get rid of it immediately! |
Re: Water in trunk
Keith ![]() |
Re: Water in trunk
It can be the gaskets between the tail lights and the metal. It will leak through that area as well.
Re: Water in trunk
Sure it isn't your tail light gaskets? I got mine from Liberty Subaru for about $50. Problem solved.
Re: Water in trunk
