Has anyone tried this oil filter??
I read that a 944 oil filter will fit the svx,true enough its about twice as long and fits perfect.This would be of great benefit for the guys running boost.
Re: Have anyone tried this mod
Yep, a lot of people are using them.
Yeah, that's all I've even ran in my car.. I believe it's all OT uses, maybe.
By the way... Your title should be: Has anyone tried this mod and not have
you could always just go this route and only change like once a yr.
so far so good on my svx. http://www.amsoil.com/catalog.aspx?code=EAO20-EA btw - why would this be gr8 for those running boost? especially since there aren't that many boosted EG33's
WFO! http://www.cardomain.com/id/Schralper "You all laugh cuz I'm different I laught cuz you're all the same." |
Because since the filter is larger it should in theory provide cooler oil to a turbocharger,also it increases your capacity to hold a little more oil.I'm already thinking about fabbing up a coolair duct.
This is the only size oil filter I use on all the SVX's I have owned...
also found the Mazda RX7 filter works like that for the Miata and my Justy.
David 96LSi 102k Laguna Blue 95 LS-L AWD, Safety package, 140k Polo Green the Chick Magnet: 91 Justy GL EFI 4x4 154k (new motor @120k) 90 Yamaha V-Max 82 Yamaha XJ650LJ Turbo My Diver Propulsion vehicle: 88 Jeep Cherokee 160k "U-sta-have" 88 XT6 AWD Pearl, 86 XT Lt Blue, 85 XT AWD/4x4 Turbo Space Blue |
When I found this I put it in my locker.
http://www.subaru-svx.net/photos/use...svxfiles|29215
if you think that's gonna make a difference w/ cooling they make these things called oil coolers that work WAY better. btw this thread is pretty much a
I think the increased surface area of the element will allow for better flow through the filter at high volumes which effectively will help cool the oil and keep it circulating well at high RPMs, right where we need it most. While we may have known about them for a long while, a reminder for the newer folks is always a good thing Thanks for bringing it up, and thanks OT for discovery it Tom |
