Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Other Mods
Old 10-20-2008, 04:31 PM
Manifold paint
After much searching, I FINALLY found a manifold paint to use on our intake manifolds. It gives the same color, sheen and texture as when the car left the factory.
PLASTI-KOTE REBUILDERS CAST ALUMINUM FINISH
More information on the paint can be found http://www.plastikote.com/products/S...st-Finish.html
A fast-dry lacquer that resists oil, brake fluid, and gasoline and is heat resistant to 500°. Our manifolds rarely reach 200°, so its not a problem.
It definitely meets the sv-xcess standards and scrutiny and can be seen at the Pumpkin Carve this weekend. I will try to post some photos, but don't think they will do it justice.
I also use their Rebuilders Cast Gray 285 on my calipers and my engine cover.
Old 10-21-2008, 01:00 PM
Re: Manifold paint
I took some quick photos this morning to show you the results. I am more than happy with the outcome.
First, here is the product:
Plasti-kote Rebuilder's Cast Finish... Cast Aluminum #282
...And now as promised... the results:
Old 10-21-2008, 01:22 PM
mysvxrocks's Avatar
mysvxrocks mysvxrocks is offline
Im REALLY addicted! CANT STOP!
Send a message via MSN to mysvxrocks Send a message via Yahoo to mysvxrocks
Re: Manifold paint
Man that looks nice! BTW: Got a how to on how to get the ac lines to look so shiny
D.J. McPhee
2006 Infra-Red Ford Focus ZX3 ~ 67k
No longer SVX'n, Ill always miss them!
1995 Polo Green LS-i ~ 95k
1992 Dark Teal LS-L ~ 145k (04/91) #2231
Old 10-21-2008, 02:57 PM
Re: Manifold paint
Lots of time using varying grades of wet or-dry sandpaper from 400 to 1500 grit, followed my a lot of Dremel-time with metal polishes and rouges. Took about 6 hours but from then on it is easy to keep up. I either use the Lithium Ion cordless Dremel for touch ups or I hang the corded one from my hood hook and use the 36" flex-shaft to get into small places.
They haven't been touched since before last Reading. They are going to get a lot shinier by Reading X.
Not doing any more. Just enough bling to counter the other textures...
Old 10-21-2008, 03:25 PM
Re: Manifold paint
Your engine is cleaner than my kitchen counter, it's pristine!
Old 10-21-2008, 05:35 PM
Re: Manifold paint
Keep up the good work John.
I'll keep taking notes.
Old 10-21-2008, 05:47 PM
wantafastsvx wantafastsvx is offline
Re: Manifold paint
gotta give props to a cleaner than new engine bay. Wish i could say mine looked the same!
Old 10-21-2008, 06:05 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Re: Manifold paint
The glare blinds me!!!! Nice pics John.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 10-21-2008, 07:20 PM
sicksubie's Avatar
Re: Manifold paint
You're brake booster is dirty
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 10-21-2008, 07:45 PM
Subix's Avatar
Subix Subix is offline
My Other car is a GENIUS Car!
Re: Manifold paint
Wow, that looks stellar!~ Nice work! (Especially love the boxer shiny )
1994 subaru svx le 112k
Old 10-21-2008, 07:46 PM
Re: Manifold paint
John, what did you do to prep the manifold? Looks really good!
Old 10-21-2008, 08:00 PM
Re: Manifold paint
The manifold was already clean. After removing the throttle body cover and the center black panel, I just sprayed on a little brake cleaner and wiped it down a little. I also used a little denatured alcohol, especially where the manifold meets the block.
Masking is really easy.you can stuff rags into the spaces under the manifold to keep paint overspray out, If you cover a spot with tape that was intended for paint, you can touch it up with a small brush, using with the manifold paint sprayed into the paint top. perfect blend.
If it ever gets really dirty or dull, a simple light re-coat will be all it needs.
Old 10-21-2008, 08:03 PM
Re: Manifold paint
Just deciding whether to aluminum-ceramic coat it or have it shot with Polo Green Pearl... or making a mold out and making one out of clear acrylic (so I can see the vacuum rolling around inside and the ability to see when it gets low)
Old 10-21-2008, 08:11 PM
zavikan zavikan is offline
Send a message via AIM to zavikan
Re: Manifold paint
hmm...I'm not terribly impressed with that A/C condenser either...Pffft, what the heck John? You getting old and lazy or something?
'92 Liquid Silver SVX - Drilled&Slotted Rotors/Canadian OEM Seat Warmers/JDM Folding Mirrors/JDM Clear Corners/Euro Glass Headlights/Euro Headlight Level Adjustment/Euro Shifter Assembly/ECUTune Chip V.1/GARAGE QUEEN!
Old 10-21-2008, 09:06 PM
Re: Manifold paint
I'll tackle that problem if my A/C ever goes out and I need a new compressor.
