An scan tool for a '92?
I'm looking to get a scan tool for my newer OBD2 cars, and if possible, would like one that would work on my '92 SVX. I've searched this site, and I understand I can read the fault codes off the car, but is there a scanner that can read live data, reset codes and do the other things like you can with the OBD2 cars? Does anyone on this site use one on their cars? Thanks. Bill Z
Re: An scan tool for a '92?
The only one that will read live data is the Subaru Select Monitor. The "new" select monitor (Select Monitor II) will show graphs and such, the old (blue) one will just show a numerical value for each sensor, but it will only show one at a time. They do pop up on ebay from time to time.
As for reading codes, most of the OBDI scanners that do support Subarus, will just read codes the same way you can read them by counting the blinks of the check engine light, except it counts pulses at the diagnostic port.
Now, before you get the poor guy's hopes up you might mention prices for those "old" Select Monitors that pop up occasionally.
![]() ![]() Glenn
"The only thing necessary for the triumph of evil is for good men to do nothing" Aaron Burke 1993 25th Anniversary Edition #63 of 301. R.I.P. Rojo 7/24/2008 She saved my life! 1997 Ebony Mica Pearl LSI. BLACKBERRY 1998 5-Spd Legacy GT Wagon in Glacier White: NUBURU 2005 Cadillac STS in Sandstorm Metallic: STORMY Veteran and farthest traveler of 1st SoCal2MuseumsMeet2010. http://www.subaru-svx.net/photos/user.php?RojoRocket |
hehe...I think "stratospheric" is the word you're looking for there. This is not like your OBDII scanner you can buy at Napa for small beans. Select Monitors are (correct me if I'm wrong) well over $1000 (that's thousand, not a typo). That is fairly standard for shop grade scan tools though, the shop I was at last year bought a Snap-On scanner, second hand, for $3500.
You need a laptop, a cable and a copy of the Evoscan software. It reads live sensor data, does datalogging, and it's cheap. No function to read or reset error codes, but you can do that with the blue wires anyway.
http://www.limitless.co.nz Look at the last couple of pages of the "Memory Dump of ECU" thread for the correct paramenter addresses that TomsSVX found. http://www.subaru-svx.net/forum/showthread.php?t=38685 For technical info on the ECU and TCU see my website http://www.alcyone.org.uk/ssm
Subaru ECU and TCU Website 1992 Alcyone SVX Version L 1992 Alcyone SVX Version L 1994 Alcyone SVX S40-II 2004 Subaru Legacy 2.5 SE Sports Tourer 1996 Subaru Legacy 2.2 GX Wagon 1988 Subaru Justy J12 SL-II Last edited by b3lha; 10-13-2008 at 03:05 AM. |
Thanks for the replies. If I get a laptop, I may try your system b3lha, though it may be a bit beyond me. What is that building in the pic on your website? It's striking. Bill Z
The last Select Monitor II I saw on ebay went for $150, but it didn't include any cartridges, there is one cartridge that will do 97 model year and older, but I do not know what the cost is per cartridge (and the SMII uses different cartridges than the original select monitor)
I've seen original select monitors go for ~$350 with a bunch of cartridges... The SMII was ~$5000 new, and I am pretty sure the SM3 is the about the same, but it comes with a laptop (And won't work on anything pre-96)
![]() Quote:
Hello Phil,
I haven't been on this subject in awhile. The last time I was into this there was a problem with the 92 SVX codes. I think it wasn't known how to get the computer to read the codes or something. TomSVX found these? Are all the codes known now? Can you just monitor one thing now like TPS and tranny temeprature? Is it possible with this system to store data over time, data logging? Oh I see that you say yes. What about tranny TC lock-up? That would be neat plotting out TPS and Lock-up verses time. I also remember someone had a few "gauges" that could be seen on the screen. Well anyway I got the "stereo" connector! Is that still needed? I have been using a multimeter and that is certainly ME being accident prone. Watching the voltage on O2's while driving is not good. I think I would need that "heads-up" lap top ![]() Or just put it on the seat and look at when I am not driving. Peace, John
May your transmission live forever. SuperbVehicleXtraordinary Proud sponsor of a 1992 SVX. ![]() |
The "92 problem" was completely solved by a little bit of extra circuitry in the adapter. We can now reliably communicate with the ECU and TCU on all OBD1 SVXes. You still need the radio connector, but now we know how to make USB cables. TomsSVX managed to extract all the parameter addresses for the ECU from his Select Monitor and he's promised to do the TCU when he gets time. There is a new ECU software called Evoscan that has pretty gauges and does logging and plots graphs etc. If you want to log your O2 sensors, this is the one to use. Currently the only way to read the TCU is my linux program. It can display and log TCU information like tranny temperature and lockup, but it runs in a console window and looks a bit old fashioned. Hope that helps, Phil.
I should try and make time for this tomorrow... Or maybe later today if I can get the evoscan cable to reach my desktop
Tom |
