Code 34 EGR Selenoid Valve Inoperative
As noted in the title, I'm getting a code 34 and am not sure how to tackle the fix. The car runs a bit rough and is also throwing a code 28, knock sensor. I just replaced the same one on SVX #1 so know how to tackle that. I checked at SubaruParts.com and there are a lot of pieces that make up the ERG system. Is thare just a valve you replace?
Your help will be appreciated. Gene
I'm lost but if I had to replace something my money would be on part 1 or 7.
Nothing else seems to have any moving parts.
"That which can be asserted without evidence can be dismissed without evidence." '92 Dark Teal SVX LS-L, >146,000m 3 pedals, 5 speeds., restoration underway. 2012 Honda Insight, slow but cute. ![]() Last edited by NikFu S.; 09-16-2008 at 03:02 PM. |
Re: Code 34 EGR Selenoid Valve Inoperative
Part 1 is $101.66, Part 9 $48.63. I was hoping to at least narrow it down.
![]() Gene
They're both valves. :/ Maybe try removing them and seeing if either one is stuck or gummed up.
"That which can be asserted without evidence can be dismissed without evidence." '92 Dark Teal SVX LS-L, >146,000m 3 pedals, 5 speeds., restoration underway. 2012 Honda Insight, slow but cute. ![]() |
easier said than done... LOL
True but I figure at least one has to come out eventually. This way you might be unable to ungunk one if it's just gummed up with junk.
For the next person who has an ERG problem, I found this excellent thread.
http://www.subaru-svx.net/forum/show...valve+location Turned out I had printed it out a couple years ago but forgot I did. I'm going to give the non-replacement tips a try. Gene
I guess Beav hasn't been around for a while. This pic is quite useful.
![]() /saveas
When I had the 34 code about 2 years ago it was caused by a EGR sensor that is mounted under the intake manifold on the right side of the car (passenger side). I do believe that there are two sensors, but thats the one the fixed my problems.
I hope this helps. Ken |
