power steering hose pressure leak
i found where my power steering is leaking ,"hose pressure" the metal hose looks very good, i am wondering if they sell it apart, i dont need the whole pressure hose only the rubber one
Claret 92 Ls-l R.I.P - 24XXXX - kms "april 2008" rest in pieces Ebony black 92 Ls-l Alive - 25XXXX - Quick change, Powermod , Alternator Mod , audiobahn 1300 watt ach ,exile 800 watt peak, jackhammer 12" 300 watt rms, polkaudio 6 1/2 compoment. kenwood dvd\nav . radar detector.small car lens and grill Last edited by Francis; 08-30-2008 at 04:21 PM. |
Re: power steering hose pressure leak
The flexible hose is available every where. Check the pressure & temperature numbers for the line you want to replace.
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited 2012 Outback 3.6R Limited! ![]() |
That's good to know. I have the same problem, only it's leaking from the opposite end, right where it hose connects to metal adapter.
uh....do you have an idea where i can find those informations ?
Claret 92 Ls-l R.I.P - 24XXXX - kms "april 2008" rest in pieces Ebony black 92 Ls-l Alive - 25XXXX - Quick change, Powermod , Alternator Mod , audiobahn 1300 watt ach ,exile 800 watt peak, jackhammer 12" 300 watt rms, polkaudio 6 1/2 compoment. kenwood dvd\nav . radar detector.small car lens and grill |
maybe you need to torque it a little more ? , i would give it a try , for my problem its different ,the hose dryed then cracked right in the middle, when i give hard time with steering it pisses everywhere until it flow on the exhaust and makes smoke ......smells too
I've just had the pressure hose, pump and rack replaced on my steering. I'm a mechanical newbie so someone else will need to confirm, but I picked up on this -
When I asked about my problems here I was told it would be one of two things: 1. Hose clamps were worn or not tight enough 2. Metal pressure hose would be worn/have a hole. Quote:
There's a hydraulic hose company called Pirtek (worldwide) - they fitted the original clamps from mine to a new length of hose. Similar places were under 'Hoses - fittings' in the phone directory. Was about half the price of a new one & both places where I live have a mobile service. Or, if you take the hose to an autoparts store, they can identify it and sell you the type you need. http://www.pirtek.com/ Tania. hoping I haven't just made an idiot of myself
1992 Onyx SVX 184,500kms Now with new and improved no leak steering! No plants = no life on earth - so go forth and plant green things! Last edited by plantchick; 08-30-2008 at 05:51 PM. Reason: Added link |
If you have to ask if it's replaceable, you're not equipped with the tools and suplies to do it.
Fiind a hydraulic hose repair shop. Some non-chain auto parts stores do it, or find a place that works on heavy equipment (back hoe's, loaders) and they'll be able to reuse your ends. It should cost ~$30. Much better than the $80-100 to get a new one from Subaru.
that hose is in rubber. i dont think that this is rubbercovered. it is so easy to bend it any ways . and the reason why it is leaking is because it dryed and it made a crack on the rubber. im 99.99999% sure its not metal under it
i maybe solved the problem i have my other svx standing in my driveway waiting to be taken apart "spare pieces ![]() i'll try to post picture soon
as i said this is the picture of the hose
Yeah, that's the high pressure hose. Find a local shop to rebuild it.
Reading back over my earlier post, I may not have been clear. Quote:
Those hoses are a pain in the ass. You have to cut the original metal piece off, affix two new metal ends with a new piece of hose in the middle (requires crimper) and then figure out how to safely attach it to the exposed metal ends. ORRRRR you could buy an entirely new piece and unscrew each end of the hose. I just caught that in the pictures. My old Audi didn't have that handy feature.
In short, shop work. Average PSI for Power Steering systems range from 1000-2500. Last edited by williamshuck; 09-04-2008 at 07:50 PM. |
Francis it was hocrest that told me about the rebuild thing... hmm, and most of the rest, too... I now have a happy little steering system. ok, so it took a reconditioned rack and pump too, but hey...
1992 Onyx SVX 184,500kms Now with new and improved no leak steering! No plants = no life on earth - so go forth and plant green things! |
well i did not have a lot of problem removing the hose from my old\new svx....installing it was another part , to make my job easier i jacked the car ,removed passenger wheel, removed small plastic cover and i had a good view of the bottom connection , i was much easy,safer and quicker than being under the car . so finally , ITS REPAIRED !!
![]() p.s. ....its 14 mm and not 9\16 got damn i almost ****'d up the nut trying to unscrew it
Claret 92 Ls-l R.I.P - 24XXXX - kms "april 2008" rest in pieces Ebony black 92 Ls-l Alive - 25XXXX - Quick change, Powermod , Alternator Mod , audiobahn 1300 watt ach ,exile 800 watt peak, jackhammer 12" 300 watt rms, polkaudio 6 1/2 compoment. kenwood dvd\nav . radar detector.small car lens and grill Last edited by Francis; 09-06-2008 at 11:24 PM. |
