I'll start from the beginning... About this time last year my Claret SVX started squeaking when coming to a stop. It got worse as I kept driving. Brake pads were fine. With the help of some of the people on the forum, I narrowed it down to the seals leaking in the calipers. OT sent me a used caliper for the front. I replaced that and some of the squeaking had stopped. Then I replaced one of the calipers on the rear. That one silenced but the others were squeaking. It seemed that every caliper was leaking. No surprise since this is a 16 year old car. So I decided to get brand new calipers all around. While I was at it, I decided to get new d/s rotors and ss lines. I wanted to upgrade the brakes anyway, so I felt this was the best time.
Now I have a new problem. When coming to a gradual stop or slowly accelerating from a stop, I hear a loud screeching. Like nails scratching a chalkboard. OT recommend I check to make sure the heat shield wasn't rubbing against the rotor. I checked and nothing is rubbing against the rotor. I pushed the heat shield away anyway. I drove the car around my driveway to see if it went away. All seemed fine. I took the car out this morning and the screeching has started again. I'm getting impatient with this car right now. I don't even want to drive it because every time I come to a stop I'm clenching my teeth at the sound. Help?
Rebecca 92 Claret SVX LS-L (180k) 09/91 #5,732 06 Suzuki Boulevard M50 7k 68 Cadillac Coupe DeVille (70k) Storage/hibernation for now. Past SVXs: 94 SVX Emerald Pearl FWD (Sold) 96 SVX Bourdeaux LSi (Sold) 92 Pearl SVX LSL "Stay Puft" 5MT (140k) #148 (RIP) 95 Brilliant Red SVX LS (162k) 12/94 #564 "Killer Tomato" (RIP) |
Re: Brake help....
If you do a few 60-0 stops, it might wear down whatever is causing the screeching sound.
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount ( ![]() silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear ![]() (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
Re: Brake help....
tom |
Re: Brake help....
i wonder if it isn't something scuffing on the axles?
Re: Brake help....
Ok guys I will do some stops tonight and let you know if the sound stops.
Re: Brake help....
Can you determine an individual corner that the sound is coming from? That might help in the diagnosis of the problem
![]() ~ Chris
2020 Subaru Outback Touring - Wife's first Subaru 2005 Volvo V70R - 5-cylinder love! :Heart: ** SOLD **1998 Subaru Legacy 2.5GT Wagon - MOST RELIABLE car I've ever owned ** SOLD **2006Subaru WRXSTi (Former "Boxer4Racing.com / Continential Tire" STi) - Built EJ22t block / EJ207 JDM STi "big port heads" - 9,000rpm MONEY PIT!!! ** SOLD ** ![]() |
Re: Brake help....
Rebecca,
I just now saw this. Call me, or bring it here. If need be I'll come and get it! Tom
Re: Brake help....
I'm going to try and drive the car up to Tom's tomorrow. That may be my only free day for awhile. ![]()
Re: Brake help....
I had a similar problem. I know this might sound impossible, but I actually over tightened the bottom bolt on the caliper. It did not bottom out, it just protruded far enough to touch the rotor. Can't hurt to check.
Re: Brake help....
I had this problem and it turned out to be a pad guide/slide. It would be fine for a little while then things would heat up some and it would start rubbing on the flat edge of the rotor.
It would only do this when slowing to a stop, not while slowing or light braking. May not be your problem but it would be worth a look. |
Re: Brake help....
![]() Always boils down to not getting it put back together exacxtly right ![]() Keith ![]() |
Re: Brake help....
The replacement calipers came with new slides, but now that you guys mention it the new mounting bolt for the right rear was different than the standard bolt...
I'll find out today.
Re: Brake help....
Thanks Tom. Turned out to be the passenger front clip draging on the rotor. It was kind of strange, but it is fixed. For once, my brakes are actually quiet.
Re: Brake help....
Glad I could shed some light on it as well.......
