Old 08-15-2008, 07:35 AM
plantchick's Avatar
plantchick plantchick is offline
Mechanical 'L' plater ahead
Replacement of leaking power steering pump, pressure hose and rack
Turns out the 'minor' oil leak I was told of before I purchased my girl isn't so minor after all; the power steering pressure hose has a hole in it and the steering pump and rack are both leaking. The boots are intact, but full of fluid.
All of the above were easy for me to see when she was on the hoist today, even with limited mechanical knowledge.
I talked it over with the CV/Steering specialist guy who said the most urgent was the pressure hose and pump, but that the rack would probably be ok for six months or so, as long as I checked the fluid every few weeks and kept it topped up.
I know it would be cheaper in the long run to get it all done at once, but given that I've just bought her (two weeks) and had some work done, it'll be a tough ask.
I'd appreciate your opinions on what, if any, problems I might cause if I delay doing the rack for a few months.
This might sound strange, but I haven't noticed any real problems with the steering, other than finding it heavier than I expected from a sports tourer. That said, I don't have much to compare it to - my previous (and only) car was an '82 Benz who's steering was even heavier.
There's a slight noise on full turn, that I associated as the pump working on a heavier load. Other than that, no sqeaking, squealing, shuddering or jerking.
Hope I've given enough/the right information.
Thanks,
Tania.
Old 08-15-2008, 08:23 AM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Re: Replacement of leaking power steering pump, pressure hose and rack
For the hose, you may want to look at getting it rebuilt by a hydraulic hose shop, rather than purchasing new. In the US most shops will rebuild one for about $30 compared to $70 for a new one.
As to the leak at the pump, there are instructions in the "How To" documents on replacing the O ring in the PS pump, this $1 repair takes care of most PS Pump leaks.
Another item you'll want to look at is the low pressure return hose, it runs behind the right side of the engine, next to the high pressure line. This hose can be replaced with a couple feet of standard 3/8" atf line.
Old 08-15-2008, 09:27 AM
plantchick's Avatar
Hi Horcrest,
I'd be happy with $70 at this point! I've been quoted $166AU for hoses, but I believe that was for replacing all hoses. (whole job quote including labour is $1212AU) How are hoses rebuilt, as in, how do they patch or cover holes? (its about 2mm)
I have these printed out and have been poring over them the past couple of days. The O-ring between pump and reservoir I'm confident I could manage, but the bearing and O-ring in the pump itself look kinda scary. ummm... I've never even heard of locking ring pliers before.
So many things to learn! I know a lot of parts can be replaced with aftermarkets & alternatives, but learning which....
Can what's currently holding the hoses be reused or would they need to be replaced as well?
I'd really like to learn and I'm a pretty quick study, but the most I've ever done is change oil and flush a radiator.
I do have a US service manual, though! Well, at least most of it. The STIS site was kinda screwy on the '92 SVX manual.
Thanks for your help, Horcrest. Much appreciated.
Tania.
1992 Onyx SVX 184,500kms
Now with new and improved no leak steering!
No plants = no life on earth - so go forth and plant green things!
Old 08-15-2008, 09:39 AM
JLHollowX13's Avatar
JLHollowX13 JLHollowX13 is offline
Send a message via AIM to JLHollowX13
i did my pressure hose a while back, i got it for 99usd from subaruparts. it was a quick install, and the new hose has held up awesome. you only have to undo 2 parts to replace the hose, and it simply runs next to the engine, so its pretty easy to throw on. i would suggest that you try and do that yourself as it would probably save you alot of money. with these cars as old as they are doing anything yourself will save you alot.
1992 silver/black LSL - 142,xxx miles
power mode switch, ecu crush, intake silencer removal, ecutune, B&M transmission cooler
1971 toyota landcruiser - project.... someday
Old 08-15-2008, 11:45 AM
dcarrb dcarrb is offline
No expert here, and I certainly don't advocate postponing needed suspension part repairs, but I drove one of mine with a blown boot and minor rack leak for many months, checking/topping the PS reservoir weekly. So long as the leak is minor and steering performance is unaffected, I don't think you're hurting anything to wait.
dcb
Old 08-15-2008, 12:37 PM
Hocrest's Avatar
When they rebuild the HP hose they basically reuse the metal ends and put a new hose of the proper rating beteween them. In the states some auto part stores do it, someplaces you need to find a place that repairs hyraulic driven heavy equipment like front end loaders.
Unless you know that the pump is bad, just do the tank O-ring first, that has solved many people problems.
For the low pressure hose, you can reuse the clamps if they're in good shape. If any doubt, get new. I prefer the Subaru clamps that are heavy wire looped around with a screw, some like the normal worm clamp (flat strap with screw threads cut into it). For the hose, not sure if it would be called 3/8" down there, take a piece of the old to any autoparts store and tell them you need a couple feet of it, if they ask what it's for, tell them for an Auto Trans fluid cooler.
Old 08-15-2008, 01:43 PM
kwren's Avatar
kwren kwren is offline
the quality of the "worm" clamps vary a lot. Some are garbage and just look like stainless steel. If you get good stainless steel ones they are great but the bad ones can be stripped by barely tightening them. The origional Subaru clamps usually are good ... might but a drop if oil on it where the threads are.
Keith
Old 08-16-2008, 05:47 AM
plantchick's Avatar
Originally Posted by JLHollowX13 View Post
You only have to undo 2 parts to replace the hose, and it simply runs next to the engine, so its pretty easy to throw on. i would suggest that you try and do that yourself as it would probably save you alot of money. with these cars as old as they are doing anything yourself will save you alot.
I had a look today and see what you mean but it doesn't look possible without it being up on jacks, which I don't have yet. Agreed on doing what I can myself - gonna do my best to learn - I'll get there, just might take me awhile!
Old 08-16-2008, 05:59 AM
plantchick's Avatar
Thanks for the explanation on the hoses and clamps Horcrest. Spent a large part of the day traipsing around parts places and did get info on a place that reconditions hoses. Nope, aint 3/8" - we use real measurements here!
but can work it out, yeah. More on hoses below.
heh... I don't know much about a whole lot, atm, but if I remember what I've read here correctly, pooling on the engine generally points to a pump problem. Still, I'd like to see how it affects the oil loss on its own.
Old 08-16-2008, 06:02 AM
plantchick's Avatar
'ta Keith. I asked the parts guys to show me them both today and I can see what you mean - the difference in quality is obvious if you know to look.
Old 08-16-2008, 07:36 AM
plantchick's Avatar
Guys thanks for all your help - I understand a whole lot more than I did this morning.
My next question - is only the inner core of the pressure hose meant to be clamped to the fitting, with the surrounding rubber hose a couple of inches down and not clamped? A solid pipe runs accross the gap (the pressure pipe?). Is the gap because of heat from the pipe? Looks like it'd be a tight squeeze for the rubber hose, too.
Please ignore the next post at will - its just background on the issue.
*smiles wryly* I cut it from here 'cause of how long it turned out.
Tania.
Old 08-16-2008, 08:22 AM
plantchick's Avatar
Background - roadworthy issues.
I started doing the o-ring - got the cover off, drained fluid off, the first two bolts of the reservoir.... yaaaay me! .... then I noticed the hose and stopped. See I don't want him putting it back on me that I damaged something by trying to work on it myself.
There's a complication with the roadworthy certificate issued for the car. The issuer is legally responsible here for any problems that arise (within a time frame) that affect roadworthiness and the CV tech says it should never have passed. I spoke with the mechanic and he agreed we'd talk about it when it goes in for a trans service on Monday and "work something out". Its not straighforward, though - I accepted a backdated certificate because of a massively cracked windscreen (no way could it have passed as recent), but with the agreement I'd be told of any other issues. He did the roadworthy as a favour to the girl I bought the car off. Theoretically the shop can lose its inspection license for passing a dodgy vehicle.
The pump & o-ring wouldn't be a roadworthy issue, but the hose definitely is. The rack is a grey area. CV guy says the rack's probably been like it for around 12 months (she's barely been driven for the last six months).
I was told before I bought her that there was an oil leak, but he said it would be something minor and no biggie, not expensive.
Nearly a whole blo*dy steering system doesn't strike me as minor!
The mech has a good reputation around town and the CV guy was surprised when I said it was him that'd done the roadworthy and also done work on it since. I don't think he deliberately did me over, just that he missed something he should've caught. If that's all it is then fair enough - you can be good at what you do and still make a mistake.
Difficult, though -he did a major service on the car 10 days ago & washed it down to track the leak. Told me to bring it back in a few days so he could find where. I'd figured in the meantime it was steering fluid 'cause of the colour (thank you forums!) and yup, took it back in and was told it was leaking from the rack and I should probably do the hose and possibly pump. He sure didn't pick the hole and seemed genuinely surprised when we talked after I'd taken it to CV/steering guy 'cause I wanted another opinion. (the forums have also taught me lots of things get replaced when they don't need to be)
What he said was that maybe washing it down had dislodged whatever was blocking the hole. Or that changing the fluid had done it.
All the explanation is so I can ask - is what he says reasonable? CV man seemed to think it was pretty poor. I don't want to cause this guy trouble or screw him over, but nor do I want to wear the cost of bad work.
If you've made it this far, thank you!
Tania.
aka
wordy chickie.
Old 08-16-2008, 03:46 PM
MiniGuy77 MiniGuy77 is offline
wow, i just found out yesterday from a mechanic that my power steering leak is from the power steering rack...
i'm not as mechanicly inclined as you seem to be. do you know how much you were quoted to replace the rack?
i'm kinda skeptical with the mechanic cause it is the first time i went to that shop...i'm gonna get a couple other things done at that shop anyways cause they are more of an immediate issue(timing belt) but i will get a second opinion when i get the chance...
o the fun of trying to find a good shop in my neck of the woods(abbotsford,bc,canada)...btw: i used to go to a dealership to get my car fixed but after they screwed up a couple times i am done goin to them.
Old 08-16-2008, 06:22 PM
plantchick's Avatar
MiniGuy, I'm really not mechanically minded, I've just read a lot!
Not sure how well Oz prices translate, but it was $464AU incl. boots. The link is from the forum How-To's on part numbers/prices. Its no. 6, front suspension etc. Labour on mine was ~3hrs for everything.
http://www.subaru-svx.net/photos/user.php?How-To|28204
I did do a search a few days ago and found aftermarket around $250US, not sure if that included boots.
Tania.
p.s. sent you a pm on finding techs
Old 08-16-2008, 09:51 PM
kwren's Avatar
Re: Background - roadworthy issues.
Tania.
aka
wordy chickie.
NO, not at all...
Keith
