Old 07-15-2008, 02:12 AM
aust92pearl aust92pearl is offline
Question replaced water pump now engine isnt quite running normal
starts up normal and warms up normal but when driving it it feels like it is only pulling with four or five cylinders it doesnt sound like the engine doing it though its like the gear box it labouring the engine it could just be wearing in the water pump bearing i dont know any ideas? odd
Old 07-15-2008, 03:35 AM
Re: replaced water pump now engine isnt quite running normal
You got the t-belt off a tooth it sounds like. That would be the first place to look for your issues.
blk 92' LSL w/ average mods
Old 07-15-2008, 05:05 AM
Yep. 123456
Old 07-15-2008, 06:17 AM
ok um so is it still alrite to drive with it like this how will i go about doing it to make sure its correct?
Old 07-15-2008, 08:52 AM
If its only off one tooth, you can drive at reduced power for quite a while.
However, they each could be off a tooth.
You will not know untill you double check.
There are 48 teeth on your cam sprockets, that means that each tooth off
is 7.5° of cam timing off.
Since the camshafts turn at 1/2 the speed of the crankshaft, thats only 3.75°
off on crankshaft. Not much really.
If it were off one tooth at the crankshaft, it would be off the full 7.5°.
Much more noticable when driving.
I always remove the radiator so that I can reach and see things better when changing a timing belt.
Old 07-15-2008, 11:04 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
That's because you're a SVX mechanic God!
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 07-15-2008, 01:46 PM
kwren's Avatar
kwren kwren is offline
It is not ok to drive it. Driving it could cause a more serious problem...
Keith
Old 07-15-2008, 01:50 PM
Keith
Like burning up valve seals... He's right, try and address it as soon as possible
Old 07-15-2008, 03:07 PM
ok thanks guys i will get it to a mechanic asap
Old 07-15-2008, 05:12 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
but you already did the belt once... re doing the job is the easy part!
- John
Old 07-15-2008, 07:30 PM
Wikedjuggalo's Avatar
Rebuilding
I had the same problem with it being off a tooth (really 2 I think it was) and it had a hunting idle and definatly had a loss of power. I didnt drive it but 5 miles while it was like that I think but get it fixed
Old 07-16-2008, 12:03 PM
kwren's Avatar
Smart guitar picker!
Keith
Old 07-18-2008, 02:18 AM
hey guys pulled her apart again and yep out like two teeth got it all lined up and now shes smoother than ever i supect it may have been out wen i bought her but yer shes good as new now thanks guys
