Re: fuel injectors
Are you replacing a bad injector? All of them? Don't run and spend money yet. There are a lot of stock used injectors laying around right now from all the 2v7 people.
Re: fuel injectors
there's also these options in it's bad injector
http://www.rceng.com/Fuel-Injector-Cleaning-P43C0.aspx http://www.fuelinjectors.com/ notice on the bottom of RC's page there's math. based on which it shows 370cc injectors, @ 43psi are good for up to 335 crank hp. where as stock injectors good for 235 crank hp.
WFO! http://www.cardomain.com/id/Schralper "You all laugh cuz I'm different I laught cuz you're all the same." Last edited by Schralper; 06-29-2008 at 08:43 AM. |
Re: fuel injectors
![]() ![]() I also have at least a full set of SVX red tops, but have not been re-conned as they were the ones I had in last.... but based on your post i assume you're only looking to upgrade; just putting it out there if any needs stockers.
-Mike ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts -
![]() [SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not ![]() Member #995 ![]() Catch you next at: ? Auto-X ? |
Re: fuel injectors
I don't seem to have any problems, but think it would be a good thing to do while it is not getting any road time.
The Worm ![]() _______________ June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod" Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012 '05 Infinity G35 Coupe. No Mods, 33K Miles |
Re: fuel injectors
I would proly want to upgrade... However it is going to Subaru today and they are gunna tell me what is wrong with it....
Hopefully it is not too much... lol
-Chris '94 ebony pearl, with orange "silicone" hoses, painted beauty cover, Tom's Intake, Dayles Cold air intake; with HKS mega suction foam air filter, 3in header back exhaust, STI ground wires, euro front fascia, euro front grill, reactive 17in wheels, Nitto Invo's, Drilled and slotted rotors, stainless break lines, Koni strut inserts, Drop springs, 5MT, shotshifter, Clutchmasters clutch, ACT prolite flywheel, EL Glow gauges, The ECUTune stage 2. To Do: Cams, port and polish, etc. |
