Still some stereo noise.
Hey guys.
I'm still experiencing alot of noise coming into my amps from the alternator and various other devices. Specifically when the engine is on. I now noticed that whenever i have the ventilation system to high, the speakers immitate the sound that the vent motor is making. Engine whirr is also heard through the speaker. I grounded the ground loop isolator wire on my rca's, as well as re-did all grounds under the hood and to my amps with 4 gauge. All paint was stripped and ground down to bare metal, including the bolt. A new 4 gauge wire was ran from the alternator housing to the battery also. I'm running out of options here. I reduced the noise tremendously, but it still exists. It's getting on my nerves. And yes, the wires were ran on the opposite sides of the car. Thanks guys -Ross |
try this site's troubleshooting diagram just to make sure you haven't overlooked something.
http://www.audiocontrol.com/techpapers/tech1002.pdf good luck - ground loops really suck |
are the amp grounds going to the same ground point that the battery goes to? maybe try a noise filter on the power lead.
Alan 1987 928 S4 (Black) 1997 SVX LSi (Ebony) 2005 Legacy GT (Silver) 1987 928 S4 (Black) 2008 Lancer Evolution X MR (Apex Silver) 2013 G37xS AWD(Obsidian Black) 2018 Q60 Red Sport AWD (Graphite Shadow) 2022 KIA Stinger GT2 Scorpion AWD (Aurora Black) |
No, they are not grounded at the battery, and should never be. The battery is grounded under the hood. The amps are grounded to the hatch latch, and i've stripped all paint with a grinder. Believe me, it's a perfect connection.
A noise filter is not an option since it reduces sound quality |
92 LS-L Claret / Black UR Underdrive Pulley, Bosche Platinum +4 Plugs, K&N Cone Filter http://www.ryanmacdonald.com http://www.digitalvertigo.net http://www.open-innovations.com |
You don't believe it? Well then please don't reply. I don't appreciate people calling me a liar. I ground off all the paint, varnish, and stripped the bolt and surrounding latch area to BARE METAL. I've checked with a voltmeter, and the ground is perfect. Same EXACT voltage as at the battery. I also have a capacitor in the back, so power is not the problem. The problem is incredible interference. I hear popping sounds when the brake light goes on and off while the deck is muted, as well as the heater motor whirring when it's on.
So it's obviously interference throughout the length of the RCA and not just the ground. |
Heh ok then....
![]() Anyways, why not try running a straight RCA from the head unit to the amp, without putting it along the floorboards then. I don't see anything electrical that could be causing your problem in running it back there, but who knows maybe there is a nick in your RCA cable or something you haven't found.
That's a very good possibility, nvrmore, because upon further troubleshooting, i found that its my monstercable pair making most of the noise, when compared to the stinger hyper rcas. The monster cable rcas come with the ground loop isolator, and cost alot more than the stinger, so this incident is quite ironic. And frustrating, to say the least.
-Ross |
"No, they are not grounded at the battery, and should never be. The battery is grounded under the hood. The amps are grounded to the hatch latch, and i've stripped all paint with a grinder. Believe me, it's a perfect connection."
if its a perfect connection, why do you get all the noise? i didn't say to ground it to the battery- i said the same POINT as the battery. mine is grounded to the same point the battery is, on the sheetmetal below it. all the metal between your hatch latch and the negative terminal of the battery is resistance. i have no noise whatsoever, excellent sound. " A noise filter is not an option since it reduces sound quality." ...and the ground noise is better?
