Difficult Start, Rough Idle then its fine...
Hey All,
Been a while since I have posted. I just broke the seal this week on the SVX and brought it out of its winter hibernation. The car is a 1995 SVX L AWD with about 56k original miles. Been since last year that I have had this issue. The car turns over but I have to crank it 5-8 times or more in some cases, to get it to start up. Each time it sounds a little more willing to start and catches and idles for a few seconds but then stalls. I keep cranking and it then eventually starts up and then idles but the idle is rough. If I keep it idling for a couple minutes or so the car then starts to smoothen out and within 3-4 minutes it's a completely smooth idle. In some cases I will throw a CEL but it will go away once the idle smooths out. I noticed that the engine cooling fan stays on until the idle smooths out. I don't know if that is normal or if its a side effect of the rough idle. Once the idle smooths out the car performs without a hitch. Last year before putting the car away I ran it with a couple tanks of Chevron Techron Fuel System Cleaner. It seems to have helped the idle smooth out sooner but I don't know if that is just coincidence. Spark plugs have been changed. They were changed out after this issue came up. I don't know what the deal is. If anyone has any feedback it would be great! Thanks, Yoshi
Yoshi [B]1995 SVX L AWD - Original Owner 65k - Brilliant Red Mods: K&N Drop In Filter, Sony aftermarket CD/MP3 Stereo and Speakers, Sumitomo HTR+ Tires 2004 Mazda 6S 5-door - Steel Grey - 5 speed manual transmission - Daily Driver 2011 Mazda CX-9 - Wife's ride |
Might be something that is Coolant Temperature Sensor related.
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount ( ![]() silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear ![]() (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
When you try to start it...
Does the engine seem to turn over fast like normal?
+1. Get that code to make the diagnosis easier?
Did your issue start before your k&n filter,my car would stall at lights and my idle was very rough with the drop in filter,switched to a conical no issues,or your o2 sensors could be going.
I've had/have similar issues. But no CEL.
I think it might be the air diverter under the manifold. I've found if I turn on ignition but not start, wait 10sec and then start it seems fine. I have a K&N drop in but the issue was there before the air filter. I'm gonna clean MAF and replace O2 sensors in a couple weeks. I'm also gonna send the injectors out for cleaning before to long.
WFO! http://www.cardomain.com/id/Schralper "You all laugh cuz I'm different I laught cuz you're all the same." |
when trying to start,
does the engine turn over fast... like normal but no start?????
sounds like water temp sensor. but could also be crank/cam position sensors
check the cel. the code would be stored on there even if light doens't stay on |
I'll pull it and see what the MAF looks like. I doubt it though, if it was the MAF then why does the problem seem to resolve itself once the car warms up? I thought about the O2 sensors but I thought when they "go" all that happens is I get poor gas mileage? I am I wrong? Thanks! Yoshi
The car cranks like normal it just won't start. The battery is fully charged and has been on a trickle/float charger all winter. It takes about 5-8 (or more) tries to get it to start.
Thanks, Yoshi
Sorry,
no idea
Still waiting on the code... Lil' help?
