Old 02-17-2008, 08:09 PM
jeffast jeffast is offline
I kill more trannies then god
door handle removal
ok so i need to change my doors out because of a car accident, how do i remove the exterior handles and locks so i don't have to get 2 separate keys?
1991 xt6 eg33?
1993 gc track car
Old 02-17-2008, 09:11 PM
redlightningsvx's Avatar
Collision Refinishing Tech
KEY LOCK REMOVAL
1. Remove the trim panels (2 screws near mirror, two screws in armrest pocket, and 1 screw under the door handle-you have to remove the plate under the handle to see the screw)
2. Make sure you window is up and turn the rod holder to dissconnect joint, and then loosen spring securing key lock
3. Remove key lock from outer handle
OUTER HANDLE
1. remove trim panel
2. Completely close door window lower galss. then detach outer handle and key lock from door latch rod.
3. Remove blind cap covering hole and loosen nut securing outer handle, and then remove bracket from inside.
4. Renove handle from outside
This is straight from the service manual
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
