Old 02-11-2008, 02:30 PM
boostinsidewayz boostinsidewayz is offline
trans problem
i tried searching, went through some things but didn't find anything with the same symptoms.
the car will drive in 1st and 2nd, but goes into 3rd and just revs up. not sure if it even tries to go into 4th.
i just bought new fluid. i'm gonna go out and change it now. what should i look for?
btw, i've only had this thing 5-6 weeks, and no signs at all of trans problems. i was beating on it last night in the mud. and i drove it home 30 minutes with no problems. temps were about 10* last night if that could make a difference.
thanks for you help guys
Old 02-11-2008, 03:19 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
The trans has to reach operating temp before it will "lock up"....really cold ambient temps result in it taking longer to reach operating temp. How long did you actually drive the car today?
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 02-11-2008, 03:40 PM
-Bill
35 mintues?
Old 02-11-2008, 04:03 PM
after 35 mins it should heat up enough to go into 4th... It free wheels in 3rd?? It has never flared or anything before??
Old 02-11-2008, 04:34 PM
3rd just revs up, the revs will sit real low until i gas it in 2nd. then it will rev up until it reaches the right rpms then i start to accelerate. (assuming i'm cruising at like 30-40)
Old 02-11-2008, 05:01 PM
wow... not good. I would highly suggest not only changing the fluid but check the level before you drain it.
Old 02-12-2008, 04:07 PM
SVXRide's Avatar
does the fluid smell burnt and is it anything other than light red in color?
-Bill
Old 02-12-2008, 05:24 PM
redlightningsvx's Avatar
Collision Refinishing Tech
my fwd trans did this and i think it was the high clutch that was bad
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 02-12-2008, 06:25 PM
-Bill
yup, smells somewhat burnt.
fluid was dark
Old 02-12-2008, 06:36 PM
sorry to say it but sounds like you smoked the high clutch
