Go Back   The Subaru SVX World Network > SVX Main Forums > Technical Q & A > Chris's SVX Shop
Old 01-17-2008, 08:14 PM
porschekiller porschekiller is offline
Banned
ABS craziness
okay, just had the ABS module replaced, a $750 item, and the ABS light came back on and the ABS doesn't work, but get this-sometimes the ABS light goes out and the ABS starts working, even when stopped! yup, it starts clicking on the brake pedal and I'm not even moving!
Old 01-17-2008, 08:19 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
There is a "how to" on checking ABS codes.
Old 01-17-2008, 08:44 PM
Banned
i've had tomssvx and sicksubie check for codes, it was fixed this morning, then the light started going on and off, see below
Old 01-17-2008, 09:02 PM
Hocrest's Avatar
Sorry, I can't help.
Mine wasn't working when I bought the car. I never really saw the need to get it working. With decent tires and proper driving, I was never really a fan of ABS.
^^^^Post # 3,000
Old 01-17-2008, 09:30 PM
94SubieSVX's Avatar
94SubieSVX 94SubieSVX is offline
OOC for a while
Send a message via AIM to 94SubieSVX
Originally Posted by Hocrest View Post
^^^^Post # 3,000
I'm catchin' up to you Dave heh
bLAh
Old 01-19-2008, 06:18 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Check the yellow connector near the kick panel. I had the same symptoms. If I moved the connector, the ABS light would go ON and OFF. I had a bad connection, so I held it together tightly with a wire tie and all is well.
Sorry my bad! This was the airbag not the ABS! Ignore this comment.
[IMG] code is Off
