Old 12-31-2007, 04:50 PM
shotgunslade's Avatar
shotgunslade shotgunslade is offline
My New Tow Vehicle (and daily driver)
Here is the vehicle that I bought to tow my new race car (pictures later as the build progresses). 2006 Outback L L Bean H6.
Will pick it up Wednesday. Need to get transmission cooler, electrical kit with brake controller and hitch installed.
____________________________________________
95 LS-i Red, 31,xxx; bone stock for now; Daily Driver
94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light,
2017 Subaru Forester XT, metallic dark gray, 29,xxx
2005 Porsche 911 Turbo S Cabrio, 24,xxx
2006 Subaru Outback LL Bean, 166,xxx sold
92 LSL Dark Teal, Smallcar Shift Kit - sold
Old 12-31-2007, 05:00 PM
crazyhorse's Avatar
242,000 mi on oem trans
SCHWEET!
That's-a nice-a looking Outback
"42"
Current Stable By Age:
Old 12-31-2007, 09:08 PM
subeman90's Avatar
Soobologist
don't you think that might be a little bit small to tow something like a car with?
Nice car don't get me wrong but I'm not too sure I would tow something too heavy with that.
15 OBW premium w/eyesight
Old 01-01-2008, 07:44 AM
Race car weighs 1100 lbs. with fluids. Trailer (already specced out) weighs 950 lbs. H6 Outback is rated for 3000 lbs towing. Figure I can throw on a spare set of wheels and some tools and still be under 2400 lbs. Am looking for a tranny cooler.
Old 01-01-2008, 08:45 AM
You are only saying that to make Bill feel bad about himself!
Bill, if YOU had stayed in school and got a GOOD job you too could get a cool race car and not have to pose in those human condom ads.
LMAO!!!!!
Old 01-01-2008, 09:24 AM
Speedklix's Avatar
Locker Link Solution
thats just a hair more than what I've towed with my 2.2 sedan without trailer brakes... it pushed a bit, but I managed with the MT. Shotgun's heavier H6 with bigger tires & brakes and trailer brakes as well shouldn't break a sweat!
Nice car there! I'm looking to get the same for jess, she is thinking more about a forester now though... we'll see.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 01-01-2008, 12:02 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
You mean this ad???
BTW.. Nice car Dan.... When do we get to see pics of the racer??
Old 01-01-2008, 12:03 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
I wouldn't to with it on a regular basis without trailer brakes. Then again, I wouldn't to anything on a regular basis without trailer brakes.
Old 01-01-2008, 12:18 PM
Getting electric trailer brakes. NJ law requires brakes on all 4 trailer wheels, so I've been told.
Waiting for some pic's of racer myself as the build progresses. It will basically be a street legal version of this car. Add projector motorcycle headlamps, turn signals, a demountable windshield with wipers, center and driver's side rear view mirrors, and cycle fenders on the front.
Old 01-01-2008, 12:38 PM
Hop Hop is offline
Classic SVX
What major factors determine trailer capacity? I think that my Blazer is rated at 6000 lbs.
Old 01-01-2008, 04:22 PM
Good Luck with it Dan! Very Nice!
Old 01-01-2008, 04:59 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
LMAO!!!!!
OT,
And a Happy 2008 to you, too my friend
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 01-01-2008, 06:02 PM
benebob's Avatar
I doubt it unless its over 3000lbs which is when pa requires brakes. I'd be looking into a single axle trailer if I were you. Much easier to drive and live with. Can get a 5000lb single axle trailer. I'd say your biggest problem with a Legacy is finding a suitable hitch set up which is rated above 2000lbs and 200lbs of tongue weight. Remember, the SVX is rated to tow 3500lbs.
Old 01-01-2008, 06:41 PM
Speedklix's Avatar
The car really couldn't do it with lesser tires or more than a few sprinkles on the ground
I have yet to get a real good look at them underneath, but it looks like the new OB has been built with the hitch issue in mind. At first glance it looks like the hitch attaches to the "rails" more like they did on Jeep Cherokee and the like. I would also agree with the one axle statement being much easier to live with and handle 'cept I would always have to worry about blowing a tire pros and cons to each i guess
-Mike
[SIGPIC][/SIGPIC]
Old 01-01-2008, 07:47 PM
I am still up in the air about one or two axles. I've been getting advice all over the board on this. Several people have said that 2 axle trailers are much more stable to pull, even though they are more difficult to deal with by hand when unloaded. An issue I have is resale value of the trailer. The 2 axle version has a GVWR of 5000 lbs, instead of 3500. That makes it adequate for all sorts of cars, including Porsches of all stripes. I have to make a decision by the end of the week, when I finalize my trailer order.
My 5MT SVX wouldn't be a good candidate for a tow vehicle.
