Old 11-30-2007, 10:59 AM
AlcyoneDaze's Avatar
AlcyoneDaze AlcyoneDaze is offline
<-- custom hood ornament
Send a message via AIM to AlcyoneDaze Send a message via Yahoo to AlcyoneDaze
4.11 swap - aftermath
Well, my mechanic buttoned up the car yesterday and I took her out driving. Everything seems fine, no binding around corners, FIRM shifts compared to my slipping stockbox, and ACCELERATION
(your money order is on its way Tom)
Seems I'm having one issue: when letting hammering the gas or letting off the gas at highway speeds, there is a loud rattle coming from the center of the car. Im HOPING its just loose exhaust shields... thoughts?
1992 Pearl White/Black Onyx Subaru Alcyone SVX LS-L
Donating Forum Member In Good Standing
JDM 4.11 Geared Transmission
JDM 'ALCYONE' Rear Panel
JDM 'BOXER' Eingngine Cover
JDM 'SVX' Hood Badge
L-Edition Suede Rear Seats
Old 11-30-2007, 11:03 AM
that or a bed resonator
Old 11-30-2007, 11:14 AM
Its a REALLY noticeable scraping/grinding rattle, if it helps, it also does it as soon as I turn the key to start her up
Old 11-30-2007, 11:18 AM
crazyhorse's Avatar
242,000 mi on oem trans
If not the heat shields it COULD be the Torque Converter bolts being loose. They make ugly noises. They're also not a huge deal to check.
"42"
Current Stable By Age:
Old 11-30-2007, 11:20 AM
how should i got about checking them? pictures or diagrams would help.
my mechanic reused the torque convertor from the 4.11 trans... is that going to be a problem down the road? or will it be fine if I don't romp the car
Old 11-30-2007, 02:21 PM
or a bad flex plate... i would check the bolts though
Old 12-03-2007, 11:01 AM
yea well on the highway things finally went - the car just started revving freely, and then wouldnt start at all, when i turned the key something would spin but no click... took it back to the shop and he said he will tighten up the flywheel bolts
Old 12-03-2007, 11:10 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
my guess is that your flexplate actually came loose from the TC this means that the engine will rev freely and the starter will spin the TC (but not the engine, as the TC isn't connected to the engine via the flexplate anymore). Make sure the mechanic checks to make sure the bolts didn't get wedged anywhere where they could come loose later and make things messy. My guess is that they all ended up on the highway (assuming they actually installed all of them in the first place).
-Bill
p.s. you can see the flexplate bolts through the access hole at the top of the passenger's side of the engine -- there may or may not be a rubber stopper in the hole.
Retired NASA Rocket Scientist
Center Network Member #989
Old 12-03-2007, 12:25 PM
would it be normal for some trans fluid to leak during this process?
Old 12-03-2007, 12:29 PM
SVXRide's Avatar
If the TC got jacked around, yes....
-Bill
Old 12-03-2007, 12:42 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Another possibility is that a cracked flexplate completely separated...
Where there any harsh noises when you lost power?
How much fluid are you talking about????
Old 12-03-2007, 12:50 PM
no horrible noises, i shifted down to 2 and it 'caught' for a few seconds and held power but then revved freely again. Not much fluid, probably half a quart at most
Old 12-03-2007, 02:43 PM
SVXRide's Avatar
take a look through the access hole and see if you can see the flexplate
Bill
Old 12-03-2007, 02:52 PM
This will most probably lead to transmission overheating when the weather is hot.
You should ONLY use SVX torque converters, or 4,44 torque converters, and THOSE only with 4.44 transmissions.
Old 12-03-2007, 03:52 PM
Ya know, i am not very far at all and usually I can tell you what it is upon the first inspection. I wish you would have brought it here in the first place
