Whinning noise during acceleration???
does any one elses svx whine when they are on the gas? people ask me about it n i dont kno wat to tell them i here its normal
Tom's does, but that's a good whine
![]() It's probably your steering pump. If so, do a search on the O-ring replacement. It's the best $1 you'll ever spend (unless you're at a strip club in northeast pennsylvania)
Brian |
http://www.subaru-svx.net/forum/showthread.php?t=40027 I found the videos of my old '90 Legacy doing the same thing, I'll have to upload them soon... |
Is that only happened after at certain speed?
It could be from the drivetrains, tranny or front differential. Check the fluilds' conditions.
loose Heat shields caused mine to make a slite whiine durring take off.
David 96LSi 102k Laguna Blue 95 LS-L AWD, Safety package, 140k Polo Green the Chick Magnet: ![]() 91 Justy GL EFI 4x4 154k (new motor @120k) 90 Yamaha V-Max 82 Yamaha XJ650LJ Turbo My Diver Propulsion vehicle: 88 Jeep Cherokee 160k "U-sta-have" 88 XT6 AWD Pearl, 86 XT Lt Blue, 85 XT AWD/4x4 Turbo Space Blue Last edited by ssnsltd; 09-04-2007 at 11:06 PM. |
Updated old thread with more videos, non-SVX but I wonder if it's the sound you're referring to.
http://www.subaru-svx.net/forum/show...9&postcount=12 |
Re: Whinning noise during acceleration???
Ok so heres my issue.....
When I step on the gas now, I hear a noise that very muffled, and the best way I can describe it is... like an RC car motor, or a coffee grinder, or compressed air being blown into a garden hose.... something like that. Its very muffled and only happens as the throttle is pressed. The noise increases with more load on the engine..... but I can only hear it at slow speeds or from a stop. Front diff? Checked oil level, its just above the low mark. This didnt come on gradually, I just one day noticed the noise. |
first guess is alternator whine. try doing it with the speakers off
I had similar symptom with '00 Outback some time ago; it turned out to be a muffler that rusted through - the air escaping from it made that sound.
Park, shift to neutral, step on gas and have somebody walk around your car listening - the perception of where the sound comes from could be different when you're inside.
-- Alex 1996 SVX LSi "Used To Be Black" 2010 Ford Expedition XLT EL 4x4 "Silver" |
I've got the dreaded whine every now and then it's my alternator if that helps... I'm getting a high output alt as soon as I get cash..
I sometimes hear whining when I step on the gas hard. It usually happens when my mum is in the passenger seat.
haha that is funny b3lha...
I had a bad gear whine in my 74' plymouth it even ended up affecting the stereo and was consistent with throttle position. For the stereo it was a grounding issue, the gearing was a combination of harmonic vibration (I believe) and a gear oil change as well as fixing bushings so any vibration wasn't transfered to the chassis by poor bushings and bad rubber. There are alot of places in the SVX where the rubber is worn out, this could cause more of a metal to metal contact and may be some of what you are hearing. Also tires can cause alot depending on tread. Good luck. |
Whining During Aceeleration>>>>>> sounds like my wife!!!!!!!!!!!!!
92' Claret LSL 282,000 miles 1owner(ME) 07' Pearly WRX 40k Cobb Stage II (sold) ![]() SVX+$$$+GreaseMonkey = ![]() ![]() |
