information on oil pump maintenance for motor?
replace seal and what else any input appreciated!
Also where is accesss to the pump? Thanks, Keith ![]() |
replace the front main seal is all that is necessary.
access is behind the front main crank pulley - you have to pull the timing belt to get to it.
Thanks for the information!
![]() Take care, Keith |
You should think about replacing the timing belt as long as you are already in there. Water pump isn't too expensive either, you could do it right and replace everything while you have it all pulled apart.
Thanks for the advice!
I appreciate all the help! ![]() Keith |
Front End Job
I just did my timing belt (power enterprises) in the WRX after noticing a small seal leak in my radiator (95k miles). While I had everything apart I replaced all my idler pullies, radiator (koyo aluminum), tensioner pully, water pump, thermostat (160 deg), timing belt, oil pump (cosworth), cam seals, crank pully, alternator pully, power steering pully (unorthadox aluminum on all), and crank seal (the seal being referred to in the previous post). While I had everything apart it is simple to just get it all done at once. Since you already did your water pump, there is no need to do that, but you might consider replacing all of your idler pullies. I'm going to when I finish by build.
Chuck D. 1992 Subaru SVX LS-L - Heavily modded turbo 2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods |
Happy Birthday Keith!
Happy Birthday and many more!
-Hump '99 RBP Subaru Impreza 2.5RS '92 Pearl White Subaru SVX - 136k - My first SVX -traded '92 Yellow Subaru SVX LS "Bert" - 123k -The first SVX Convertible '92 Orange Subaru SVX LS-L "Ernie" - 139k -The first SVVVVVVX (stretched SVX limousine) Okay, so the bottom two cars don't actually exist but what if????? ![]() |
Happy b-day!
Joshua 92 Ls-L pearlie 73,000 miles |
You found your car!
![]() Kidding of course!! Thanks for the happy birthday to all who responded ![]() It was a great one! ![]() |
The timing belt was American made! ![]() |
Kieth
HAPPY BIRTHDAY hope god gave you many more years to come.
Don't forget the O-ring behind the pump as well.
Todd
Down to none ![]() |
thank you!
