Tranny compatibility
Do you have a tranny compatibility list for SVX ?
preferable year and models of the car.
1992 Pearl White SVX LS-L 1991 "Red Baron" Grand Prix GTP 5spd 2002 Chevy TrailBlazer LT |
No answers?
Basically '98 and older transmissions without the spin on filter will work with the SVX. Most Subaru manual transmissions are SVX compatable.
David B. SVXipedia @ SVX-IW.COM -- SVX Information Warehouse 2.0 coming...eventually! Ebony 1992 SVX LS-L 5 spd Koni/GC Stebro 187k miles RIP (Rust In Pieces) 1993 SVX 5 spd Koni/GC Stebro Polyurethane bushings still available! Last edited by Earthworm; 05-30-2007 at 05:21 PM. |
I believe they were saying that the 05+ sti 6speed tranny is compatible, 99-2005 wrx is compatible, 94-99 legacy is compatible, and some era of the forester. My years are wrong probably but they should be close, perhaps someone can clarify... Keep in mind though, these all require modification including fabricated parts, fitting, etc, but quite a few folks have converted to manual trans, think there's around 50 on the network with a 5speed or 6speed.
Sorry for being a noob, but will any 98-older 4EAT tranny bolt in and work? I'm not looking for all the work of a manual swap and I'm looking at a car with a bad trans. Thanks.
Yeah, any trans will work and bolt up, but the SVX has a final drive ratio in the front and rear diff that is different than all other automatic Soobs. You'll need to match the rear diff to the new trans.
So I will have to replace the rear diff too?
Yeap
it will usaully be 4.11 or 4.44 i have done these transmission swaps for about two years. about 20 swaps |
Yeap
![]() Quote:
it will usaully be 4.11 or 4.44 i have done these transmission swaps for about two years. about 20 swaps including about 5 manual swap and 1 rwd wrx manual swap. |
So will I be able to use the SVX's axle shafts with the different rear diff?
easy trick
If you just directly swap the new diff for the SVX diff, you'll most likely lose the LSD since most other Soob's don't have one.
A better choice is to get the ring and pinion out of the new diff, and match it with the LSD carrier from the SVX diff. I think SVXfiles has the how-to in a link in his signature. With this conversion, then yea, you'll be able to use your stock SVX axles. Other than that, you'll also use the stock driveshaft, wiring harness and TCU.
Dave - 03 Baja - 92 SVX - 86 Brat - 08 OB 3.0 Last edited by Hocrest; 06-25-2007 at 06:55 PM. |
Could always grab a 4.44 LSD from an Outback or a 4.11 LSD from a 2.5 RS...
Rare though.
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount ( ![]() silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear ![]() (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
so would any tranny at all other than one out of an SVX be a direct fit without messing with the rear diff?
