#76
Absolutely, I'm using these on my built engines. They should prove superior in every way to the tri-metal bearings.
no not yet... the shop wanted to outsource the work so I will try and find my own place to get it done
Tom |
#78
Ya, most places don't have a crank grinder more or less balancer
Tom |
#80
You really need to get it done. We've pretty drastically reduced our bob weights and setting your oil clearances just right will make your bottom end much stronger.
Tom |
#82
The machine shop probably already washed your block after honing it and then coated the cyllinder liners with light oil (wd40 or soemthing) but double check and make sure your cyllinder liners are oiled while the block is sitting. I'm sure it won't be long before you are ready to go and I'm sure they are already oiled but always better to check than be sorry.
Are you doing Rob's engine yet? |
#83
No Rob's engine will be started after all is said and done with my motor to keep confusion to a min. Tom |
#84
Tom,
Great progress! Any pics of the work completed to date? Does the shop you took your engine to have a lot of subie experience, or are they just a very good machine shop? Did you use the old cylinder block bolts to bolt the halves together when they did the hone? Did they bolt on hone plates to simulate the cylinder heads? -Bill
#85
I had the block bolted together with the original bolts which I will continue to use for the build... They are a very highly recomended shop from the guys at my driveshaft shop. He was very easy to deal with and was willing to explain the steps he was taking and how he did them.
Tom |
#86
Tom,
Sounds like you found a "keeper". ![]() -Bill
#87
Here's the pics of just the block
![]() ![]() And the mains with the Hi-Tech Bearings resting ![]() Tom |
#88
It's Bobby...... Not "Rob".
#89
Hey, it could have been worse, he could have called you "Ben", or "Dave", or "Old Tom" ![]() ![]() -Bill
#90
![]() ![]() ![]() Tom |
