A/C Tune up
My A/C is a bit weak... the air that is coming out is pretty warm or just a tad bit cooler than outside air and does nothing but keeps the car at roughly the same temperature. Was wondering if there is a tune up out there to fix this problem. And whether it can be done without going to a shop or anything exotic.
I am a lazy forum user, after doing a few searches the only things I found were off topic from this one. Thanks -Sov13t
Subaru SVX 94' Laguna Blue - 8.5 C/R Built Motor, 6spd |
If you just need a recharge and you may be able to do it yourself.
Could you identify is your freon is R12 or R134a? Ask Tom! SVXfiles-Tom, are all 94 SVXi including FWD using R134a? PS: btw, there's no 94LS-L, according to ur signature. ![]()
![]() I will be visiting Tom shortly... was going to do it then, but guess couldn't wait. ![]() Yeah, I do think that all it needs is a recharge, will have to check on what it is once I get home from work.
when are you going there?
i want to come and meet u ... also can you let test drive ur 6 spd plz!!!!? ![]()
Probably next weekend, once all of the parts come in... can you drive stick???
what?!!? what stick!!!?? what stick are u talking abt ??
![]() it's so tempting, if you're generously enough to let me feel the sti 6spd and i can also visit tom k, that'll be so wonderful ![]() ![]() so next time when i'm rich, i can also ask tom k to put in a sti stick in mine and a 100hp electric motor so my svx will be fast/faster and improving more mpg! ![]() ![]() btw, is yours a cable-clutch or hydraulic clutch?? by the way, have you found out your AC is R12 or R134a?
If it's a '94 it should be R134a.
6spds are hydraulic clutch only, to the best of my knowledge...
No I actually haven't had the chance to check out the A/C... washed the car and repainted the wiper arms... they had some rust spots that started to annoy me... probably will do a check on it tomorrow. As far as driving it... sure, as long as nothing crazy is attempted, of course would have to ask Tom if having a mini meet (not like he doesn't have one everyday in his drive way ![]()
are you sure? for all '94? even the 94 LE fwd model? sometimes they might have different batch for the same year? I can't be sure until I look at that because a friend of mine's 94 fwd is not blowing cold air. I have to look at it then I will know what he needs.
![]() Let's go and have a spin ![]() ![]() But I ain't sure if I can make it at the weekend. I usually have all schedule to work at the weekend. : ( Most mondays I'm off. But if I can't meet you and visit Tom and have a feel on ur 6spd, that's fine also. =p I have already tried a lot of different sticks. By the way, as of right now, when are you planning to go to Tom there? If our schedules are not matched, see you next time. ![]()
