vans are priceless, especially when u have k&n air filter, electronic gauges, flux capacitor, lightening rod, and a lead foot. i just got my minivan running,, shes a beast!!!
Budfreak...thanks but no thanks...didn't realise it's in imperial.
Cheers, Matt |
I got the gauges in and I have the battery gauge and water temp hooked up and working. I'll get the oil pressure working in the next few days.
[SIGPIC][/SIGPIC] STi BBS wheels,legacy gt 4.44, 3" catback exhaust, Stance GR+ 7k/5k, QS Teflon adjustable endlinks, Hankook EVO 245/40/17, 95-LS escaine seats, GC8 V7 steering wheel, JDM clear corners, small car clear lenses, Alcyone badge, JDM rear taillight, 97 grille, stevesby bumper, PWR radiator, Perrin Crank pulley, Urethane Swaybar bushings, urethane diff bushings, DDM 6k 55watt lows and 4500k 35watt fog lights; $15/15min mod, Motorsport whs 22mm rear swaybar, QC shift kit, ToMyx intake, z32 aluminum calipers 13" rotors, nitrous express proton + wet kit. |
Cool. It seems the temp. gauge is a little off(Reads in the 200-210 range), But once I get use to it I'll know what's going on I guess.
Those are slightly different than what's listed on Summit's web page: volts from 0 to 16,I wonder if it's the sensors that determine the range, and the display is actually capable of wider values. Here's the installation manual (one-page PDF). Not much to it. Looks like the specs you posted were from that.
David C. 1996 Laguna Blue Pearl SVX L AWD See my home page for SVX radio install/removal instructions and wiring harnesses |
I think they changed something in production and never changed it in the catalog. I've seen the gauges maxed out and at minimum and the specs I listed are correct. The temp. gauge never drops below 77 degrees whether hooked up or not. |
