Broken Tranny Mount Common?
Does this tend to be a common problem for you guys? This is the 2nd car ive done it to. I'm beginning to think it may be an operator error thing.
![]() ![]() OEM repalcements are rather pricy, but a few members can modify cheaper ones to fit our cars, saving $$$. If you can't do it yourself, someone local may be able to, or perhaps a member in the area might be able to assist. Otherwise you can have someone modify it for you and ship it out to where you are. Bad tranny mount just means the rubber moutning is gone. Broken indicates to me that it's no longer attached, in which case you have a world of other problems.
Might want to check your motor mounts as well. Chances are if one is out, the rest may be, and from what i hear it's easier/cheaper to do all at once, rather than spread out.
The '95 I bought a few months ago had a broken one-- the rubber cushion on these mounts is bonded directly to the metal plates of the bracket, and I think the rubber just deteriorates over time to where it can't handle the stresses, causing the rubber cushion to shear off the metal.
I'm not 100% sure which mounts you are all speeking of, but i fixed some this week end. I read on another thread somewere to use 3M Window Weld and it seems to have worked great!!! no more thuds when i put it in gear, no more driving vibrations, and firmer everything. it took me like half an hour and 12 bucks
