Exhaust Scraping
http://www.subaruparts.com/subaru.diag/2/i440-A.gif
Hi all, I was changing the oil and inspecting my o2 sensors yesterday when I noticed both of my front exhaust pipes are scraped and bent somewhat. The pipes I am talking about are directly between the exhaust headers and the catalytic convertors (where #7 and #14 attach in diagram) Does anyone know the part numbers for these? They are bent enough that I think it may hamper performance/emissions. Please Help!
1992 Pearl White/Black Onyx Subaru Alcyone SVX LS-L Donating Forum Member In Good Standing JDM 4.11 Geared Transmission JDM 'ALCYONE' Rear Panel JDM 'BOXER' Eingngine Cover JDM 'SVX' Hood Badge L-Edition Suede Rear Seats |
To clarify, the pipes that the o2 sensors plug into, they are bent. What are they called, whatz the part number, and should I bother?
check if you have an exhaust leak. you could probably hear it.
1992 Subaru SVX LS~L Ebony Pearl 1992 Dodge Stealth R/T Firestorm Red 1992 Subaru SVX LS~L Pearl White 1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD 2007 Subaru Legacy Spec B. Diamond Grey Metallic |
no exhaust leak. The car still sounds normal...
is your car dropped? have you noticed any scrapping sounds before? speed bumps maybe?
my car is dropped and i really have watch where i go. especialyl for speed bumps and pot holes
No, stock ride height, but I live out in the sticks, the last thing I remember scraping was a rather steep driveway incline, maybe a curb or two. There is no holes in it, each pipe on both sides are just bent in and have curb rash.
well...as long as it doesn't seem too bad, then i guess you would be ok.
Those look like the precat pipes..your diagram should have the p/n on that website page from subaruparts.com or should be in the vicinity of that website page.
Are you throwing any C/E codes? |
I think you are looking for the exhaust manifold part numbers...the short elbow pipes that come from the block?
The p/n's I found are 14009AA001 and 14022AA000 They go into the converter assembly 44107PA240 which is the diagram you are looking at. Someone correct me if I'm wrong. thanks |
i was assuming he was talking about the heat shields
I'm with DoD...you'd have to hit pretty hard to actually bend the pipes. The heat sheilds definitely get bent up over the years and will not affect the exhaust system's performance. If the pipes are, in fact, bent up, then you're better off going to a custom exhaust shop and having new head pipes bent/welded up.
Check SVXFile's locker ("Harry's car") for the new system he just did for NEWSVX's car. -Bill
