4.44 or 5MT?!?!
Hey there!
My beautiful but currently sad '92 Pearlie is down for the count...Transmission, front and center diff, and front CV joints...When it rains, it pours. I'm in the Midwestern wasteland of SVX oblivion; there aren't even many Subarus of ANY kind here, much less our Giugiaro-designed space ships!! So there isn't anyone here who knows what they are or how to properly work on them. I'm probably going to have Budfreak put in a 4.44 or 4.11 conversion with his external cooler and filter, but I wondered if he or anyone else could do a complete 5MT swap for about the same money. I'm shipping the car to Ohio for him, so about the same distance from IL would be no big deal if someone else can do a 5MT. I'd have about $2K TOTAL including parts and labor... Let me know if you (or someone you know of) could do a 5MT for about that. At this point, I'm just looking forward to having her back on the road, but I'd like to never have to deal with trans issues again. Thanks!
'92 Pearl White LS-L Touring SOLD 4.44 Swap, trans cooler, trans filter, trans temp gauge Color-matched rear body and spoiler, X-drilled and slotted rotors, Axis pads, s/s lines Raxles front axles |
........36% more torque in first gear ........31% more torque in second gear ........25% more torque in third gear ........25% more torque in fourth gear A 5MT/6MT swap with all the parts and labor should be around $5000. Here is a list of parts needed for the swap: ▪ 5/6mt assembly ▪ 5/6mt shift linkage ▪ 5/6mt starter ▪ Helicoil kit for starter stud (late model transmissions) ▪ 5/6mt slave cylinder (hydro only) ▪ 5/6mt Master cylinder (hydro only) ▪ Hydro clutch line (both hard line and soft lines) ▪ Neutral Safety Switch (for pedal box) ▪ Brake/Clutch Pedal assembly ▪ Clutch Kit (disk, pressure plate, throwout bearing, pilot bearing) ▪ Flywheel (transmission specific) ▪ Flywheel bolts (longer than flex plate bolts) ▪ Pressure plate bolts ▪ Transmission mount ▪ Rear shift linkage mount (stock or homemade) ▪ Matching rear differential (n/a for wrx transmissions) ▪ 2" extended driveshaft ▪ 5/6 quarts of gear oil ... and labor at around $2500 ..
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 03-02-2007 at 09:21 PM. |
Wow... I was thinking more like $1k for the transmission and differential out of a Forester/Outback, maybe a couple hundred for missing/fukt parts and $1800 for TOMSVX to install it.
Is 3k more reasonable than 5-6k? thats a big difference
1992 Pearl White/Black Onyx Subaru Alcyone SVX LS-L Donating Forum Member In Good Standing JDM 4.11 Geared Transmission JDM 'ALCYONE' Rear Panel JDM 'BOXER' Eingngine Cover JDM 'SVX' Hood Badge L-Edition Suede Rear Seats |
It CAN be done for much cheaper than 5-6K, from what I've read. A cable clutch, slightly older trans, if you can get into some sort of U-Pull yard and yank your own trans and parts you may be able to save a ton on parts, if you're up for some wrenching.
All other things being equal, I'd go for a manual trans. I'll take a manual anything over it's auto equivalent any day.
If you're a mechanically inclined, have tools, jack, welder or access to one, and some patience you can do the 5MT install, for much much less then 3k if you pull the parts yourself.
Agree that manual is the way to go. I've driven both and the stick is a blast!. If you're paying for someone else to do it, I'd drop the extra cash for the 5MT. Nothing like dropping the shifter into 4th at 65mph and feeling the SVX smoothly glide past others. I will never go back to the Auto for my daily driving. I feel totally connected to the car. And the 3.3 sounds bad a$$ at 4000rpm. My experience is, you can drive a manual trans until the wheels fall. I've yet to see an Auto outlast a Manual trans, which means longevity, with less headache, for the SVX. ![]() Good luck! P.S. You can get an idea on what 5MT parts might cost at a regular auto salvage yard from http://car-part.com Keep in mind all prices are negotiable so multiply all parts by 70% and you'll have a good estimate. Last edited by svxcuseme; 03-02-2007 at 04:26 PM. |
I just don't have access to parts or the personal knowhow to do the manual myself, and unless someone wants to step up to offer these to the community for the same $ as the Auto, it'll be out of my budget for now...
I'd LOVE to go manual, but the budget I have for the 4.44 is all I have, for either option... Also, I need the car to be running ASAP, so waiting on myself to figure out and complete a manual swap isn't an option right now...
I did the 4.44 auto swap in June 2006 and am pleased(or should I say my wife is pleased
![]() Damian
1992 SVX LSL Ex wifey has it now pending self destruction 2001 Legacy mods to come 1992 Subaru Legacy 2.2 214k Boob wheels CANT KILL IT ![]() |
you know Mike... I have a pearly 5mt... It wouldn't take much to get me to trade you your's for mine plus a little extra. I have a couple good trannies for her here
tom |
-Pavan |
LOL! I saw that on your site, and I've been debating it since I saw it.
I'd have to swap the trunk and the little side things by the rear windows; mine are color-matched, but I didn't think you'd mind that... The real issue would be the massive dent on the rear 1/4 panel. I have no idea what it would cost to have that repaired and painted; not that pearl is easy to match. I am considering it though...What difference $ did you have in mind?
I'm back in town and ready to go for you.
send me some pics and all other info on your car. Instead of using your parts, it would be better to have my trunk lid and side pieces painted to match my pearly because yours is probobly slightly different. I will check on the prices on doing this.
tom |
I got confused...The Ohio guy I've been talking to about my trans also has a '92 pearlie 5MT for sale, but it is much less expensive than yours. It has some paint/body issues, I believe that's the reason for the price, I think.
Anyways, I don't think i could afford yours, even with trading mine, so I apologize for any confusion and/or misunderstanding as it was all completely my doing. ![]()
