Old 03-01-2007, 09:19 PM
Hop Hop is offline
Classic SVX
Don't get pissed, send the author a note with the quote and let them know that comparing courses, you learn 3 times as much in a psych class as compared to the lower valued anthropology course. They'd probably never open it but it would allow you to blow off some steam.
Did your teacher write the book? If so, you might want to leave it alone - at least until you get the grade.
Old 03-02-2007, 07:49 AM
Speedklix's Avatar
Locker Link Solution
"Organisms could last longer if they were built better. A Subaru costs less than a lexus, but it is of lower build quality. As a consequence, a lexus is not expected to break down as often as a Subaru is."
Bet this guy has only owned toyota products.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
