which cam seals to replace w/maintenance?
I am doing major maint. on my 92, and recall reading about cam seals leaking, and replacing them as preventative maint. when you have it torn down for the timing belt etc.
I have seen more than one cam seal listed on some parts lists, and want to know exactly which ones are the typical replacements. Part #'s if possible. Thanks, Robar |
806733030 Oil Seal $5.46 (front crank seal)
806732150 Oilseal-32x45x8 $6.11 (cam seal) I'd replace both while you are in there. You need 2 of the cam seals, 1 of the crank seals.
Might as well order the "dummy" cover for the other cams. It also seems to weep a bit as the SVX ages and they're only like $3 each.
-Mike ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts -
![]() [SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not ![]() Member #995 ![]() Catch you next at: ? Auto-X ? |
Thanks for the info
Thanks - I think I have most of it on the way - need to order a bit more though.
