Old 01-26-2007, 09:07 AM
agxus agxus is offline
Question Tight Cornering Braking
Hi,
I am new on this site.
I am from Romania and own a 1992 AWD SVX.
I had problems with the transmission and recently I had the transmission rebuilt, but still the tight cornering braking is a problem.
When I start the ignition , the power light is blinking 16 times.
I read the possible reasons for this and I found:
1. Throttle position sensor ( is OK)
2. Duty solenoid C ( is working)
3. Speed sensor No 1, how do I check it?
Kindly asking anybody which can help me with an idea, to send me an advice.
Many thanks in advance and best regards,
George
Old 01-26-2007, 09:43 AM
Welcome to the site George. I hope someone will be able to help you with your problem. Good luck.
Old 01-26-2007, 12:47 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
ok there is a code being set for your transmission you need to read up on how to check it at www.svx-iw.com just click on SVXpedia on the top and click on the link to checking error codes then the one for transmissions... it is the best write up you will find
- John
Old 01-26-2007, 12:48 PM
Suby Fan's Avatar
but if i had to guess i would say Solinoid C is bad on your car
- John
