Rear wheel bearing fix
anyone have a estimate of the average cost to replace one of the rear wheel bearings at a shop? id do it myself but i dont have a bearing press.
It's $88 for the part after shipping. Who needs a press when a 9lbs sledge and a piece of 2X4 works just as well....Thats how I've put in all my wheel bearings for all my cars.
![]() ~Jedz
1994 Subaru Legacy L-6 FWD 5-speed EG33 powered |
My overall cost for a 91 Legacy was 60 for the bearing and 60 for the hour of labor.
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount ( ![]() silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear ![]() (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
I just did my wheel bearings. Bearings, nuts, and seals from Subaru OEM, and the shop took 2 hours for each side at the standard labor rates.. I feel raped
1992 Pearl White/Black Onyx Subaru Alcyone SVX LS-L Donating Forum Member In Good Standing JDM 4.11 Geared Transmission JDM 'ALCYONE' Rear Panel JDM 'BOXER' Eingngine Cover JDM 'SVX' Hood Badge L-Edition Suede Rear Seats |
For me, parts from Subaru were $70ish, and i got lucky on the labor. i found a shop that claimed to be willing to do it for 90 bucks. they had no idea they needed to rent a press, and i failed to mention it, but they honored their quote. DO NOT forget though to flush the bearings of the grease they came packed in and repack them with synthetic. These prices are for both bearings, btw. It's a waste of time to have only one replaced. You'll just be back in a few months for the other one. Do them both if possible.
Kevin Crutchfield Neophyte SVXer 92 LS-L Ebony/Lqd. Silver, stock, 88xxx miles, flung into a telephone pole by a drunk a month after buying ![]() 92 LS-L midnight black 141xxx miles, WRX FPR, MAF bypass, lightened underdrive pulley, formerly AppstateSVX's Last edited by craftylandshark; 01-07-2007 at 11:07 PM. |
My shop said my axle nuts were fine but went ahead and used my new ones from Subaru. Would there be any harm in skipping new axle nuts? I know they're cheap, but so am I
I recently paid $185 labor/machine shop fee total for both sides.
dcb |
However, because the SVX is so sensitive to the torque on the rear bearings, re-using the nuts in the back may result in improper bearing pre-load, which can greatly reduce the wheel bearing's life. If there ever was a car that I'd say "just use some new ones, it's cheap insurance", it'd be the SVX's rear axles.
3 turbos, 28 cylinders, 96 valves, 18 cams, 1400hp/1600ftlbs: '09 Outback XT / '06 Outback Sedan / '02 WRX / '94 SVX / '01 F-250 SuperDuty |
Not that it doesn't work on most cars but how long has you're bearing held up on the SVX. I'd say probably 90% of the issues are related to this method of r&r of the bearing which then leads to a bad hub so even if done right the second time the bearing isn't seated properly. Its easy to bang it in and out but not always the wisest idea. ![]()
