#106
He told me they would do for over 400 hp! Said they are an exact fit for our car? I just want ones that will help me get the most out of the FLATT intake and exhaust I will be getting later this year!
And of course the stage2v7 ecu tune and z32 MAF!
1986 4WD Turbo XT coupe 5sp.(XTINCT) 1987 4WD Custom Turbo XT coupe (XTLUNAC) 1992 SVX LS-L (LUNACY) former: 1991 4wd XT6 5sp. (SUBDUED) |
#107
~Phil Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog. |
#108
just curious, why are you going with FLATT pieces? The only intake systems I've seen them offer are for the single intake TBs that come on other subies. The exhaust system they offer looks nice, but I don't see how it's going to offer you any more performance than a good Magnaflow-based system. Do you have a sound clip for it that you could compare with a Stebro system? -Bill
#109
Ok, I've determined that when the fuel cut kicks in during engine braking the timing drops down to 8 degrees. This leaves us two options for the manual transmisison fix. Either i set a 18 degree floor in the timing table and those with manual transmissions wire up their ecu so that it doesn't initiate engine braking or I make seperate manual transmission version of the software.
#110
How hard its it to wire the ECU so it doesn't initiate engine braking? If its just a jumper or something easy the I would think its easyer for you to just make one chip.
#111
I don't have a factory service manual with me right now to look up the wiring shematic and which gear positions don't have engine braking but I remember that one or two of the gear positions do not have engine braking. We have all the signal sources available. We can get 5V if we need it from the fwd fuse location. We can get ground anywhere. If we need a pull down or a pull up we can just add a resistor in the connection to the ground or 5v. Using standard relays it should be pretty easy to tell the ecu it's in neutral when the clutch is depressed and in one of the gears that don't have engine braking when the clutch is not depressed. With that done the engine will no longer cut fuel and timing thinking it should be engine braking with the auto trans.
engine braking? we don't need no stinkin' engine braking!
-Bill (RB25DET 370 cc injectors now on site!)
#113
Bill-
About the FLATT stuff, I know it is expensive and a PITA to get over here but I would just like to have my svx be a little different. I agree that it may not be any better than a good magnaflow setup(even dayle asked me why not go with my magnaflow and MS intake?) and I just want a unique setup. Ever since I laid eyes on the FLATT stuff my compulsive buyer side kicked in and now it is a goal of mine. Maybe its stupid, but it is how I want my svx. Just a nice NA build in the end is what I want, nothing TOO complicated The ECU tune seems to be the best other option to enhance performance along with a PWR rad and some 4.44's!(that is about the extent of my build I am planning) Glad you asked =) any suggestions?
#114
While the FLATT exhaust is kind of cool looking and will allow you to say "I've got a FLATT exhaust" , I'd seriously save my money and pass on the FLATT intake. Use the money and fabricate a true cold air system that draws air in from the wheel well. I'd also pass on the PWR rad unless you're looking to go turbo or supercharged eventually. There are at least two or three other viable radiator options that are available now for less $$ (contact SVXFiles for one, the other two are on Ebay). Going with 4.44s is an excellent idea, see SVXFiles for the best deal in town. As far as ECUTune is concerned, I'd wait for the new stage 1 chip LAN is working on or the 370cc injector-based stage 2 chip LAN is also working on. -Bill
#115
glad to see you guys are staying on topic
I was just out test driving some software and took a few minutes to pay attention to the fuel cut. It comes on during complete decell in every gear selection but N. That means the ECU should just be wired to always think it is in N and then the nuetral safety switch should be wired to the clutch pedal. |
#116
Hey, I tried (check last sentence of my post) -Bill p.s. did the valve springs show up yet?
#117
Stage 1v5 is finished. Thread has been started
http://www.subaru-svx.net/forum/show...493#post445493 please refrain from talking about your favorite exhaust systems etc in the new thread |
#118
Very sorry LAN
no intentions of hijacking. My apologies.
#119
No worries, it's all good. I'm just trying to get the new thread off on the right foot.
A little Skyline for the EG33
looks like we'll need new electrical connectors, as the location of the two prongs is not the same.... and yes, they squeeze right into our rails (I'm still going to get them pressure checked) Note: kudos to the Subaru engineers - the bolts for the injector caps on our rails are phillips head and hex head, while the RB25 caps' bolts are just phillips head (what a pain!) -Bill (shipping parts out to be blueprinted...)
